[gdal-dev] OSM extract: Too many different keys in file
Even Rouault
even.rouault at spatialys.com
Fri May 13 05:45:06 PDT 2022
Tobias,
please file an issue about that at https://github.com/OSGeo/gdal/issues/new
We can likely increase the limit and make it runtime configurable
Even
Le 13/05/2022 à 14:30, Schmetzer, Tobias a écrit :
> Hello,
> thanks for that helpful analysis and hints! So I get the planet.pdf
> file is read in entirely before any spatial or key-wise restrictions
> are applied to narrow down the data that needs to be treated.
> Of course using a 1°x1° area in a planet file doesn’t make much sense
> but this tiny area was just a test run on the huge file. In the end I
> need to scan a way larger spatial area.
> As of now I am restricted to non-Java based tools on the Windows
> platform (Java has been abandoned years ago by our IT department due
> to vulnerability) so I cannot use the versatile Osmosis tool.
> I was already considering to loop over all continents which are
> supplied as well by some OSM partners but clipping the planet file as
> suggested will probably be more efficient as the data source need to
> be read in only once and this seems to be the main time consuming
> factor – given the required area doesn’t exceed 32768 keys either.
> I could imagine the following improvements for gdal‘s osm extraction
> algorithm that could be discussed based on this experience
> 1.Improve the error message: “Too many different keys in file” ->
> “Total number of keys in data source file exceeds the defined maximum
> of [DEFINITION]. \nNote: All keys are read in before any other
> boundary conditions are considered. You may consider clipping or
> splitting the data source file.”
> 2.Make the current limit of 32768 a definition (#DEFINE) and enlarge it
> 3.Have the algorithm read in only features of the given area (Makes
> only sense if .pbf files contain spatial indexes)
> For number 1 and 2 I can create a PR. For number 3 I could create a
> feature request.
> Any opinions?
> Tobias Schmetzer
> *Von:*Rahkonen Jukka [mailto:jukka.rahkonen at maanmittauslaitos.fi]
> *Gesendet:* Freitag, 13. Mai 2022 10:58
> *An:* Schmetzer, Tobias <Tobias.Schmetzer at zae-bayern.de>;
> gdal-dev at lists.osgeo.org
> *Betreff**:* Re: OSM extract: Too many different keys in file
> Hi,
> The error comes from
> https://github.com/OSGeo/gdal/blob/master/ogr/ogrsf_frmts/osm/ogrosmdatasource.cpp#L2067<https://pulsar.zae-bayern.de/OSGeo/gdal/blob/master/ogr/ogrsf_frmts/osm/,DanaInfo=github.com,SSL+ogrosmdatasource.cpp#L2067>and
> it happens before your SQL, when GDAL is reading the data in from the
> huge planet.pbf file.
> if( nNextKeyIndex >= 32768 ) /* somewhat arbitrary */
> The error means that there are more than 32768 keys in the planet
> file. Maybe that hard coded limit could be enlarged but if you need
> for example 1 by 1 degree area I believe that there are much better
> tools than GDAL for splitting a subset. I would recommend to try for
> example osmosis
> https://wiki.openstreetmap.org/wiki/Osmosis/Examples#Breaking_OSM_file_into_several_bounding_boxes<https://pulsar.zae-bayern.de/wiki/Osmosis/,DanaInfo=wiki.openstreetmap.org,SSL+Examples#Breaking_OSM_file_into_several_bounding_boxes>or
> osmconvert
> https://wiki.openstreetmap.org/wiki/Osmconvert#Clipping_based_on_a_Polygon<https://pulsar.zae-bayern.de/wiki/,DanaInfo=wiki.openstreetmap.org,SSL+Osmconvert#Clipping_based_on_a_Polygon>.
> The cropped .pbf file probably has less than 32768 distinct keys and
> GDAL can handle it. You would also save very much time.
> -Jukka Rahkonen-
> *Lähettäjä**:*gdal-dev
> <gdal-dev-bounces at lists.osgeo.org<mailto:gdal-dev-bounces at lists.osgeo.org>>
> *Puolesta***Schmetzer, Tobias
> *Lähetetty:* perjantai 13. toukokuuta 2022 10.47
> *Vastaanottaja**:*
> gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
> *Aihe**:* [gdal-dev] OSM extract: Too many different keys in file
> Dear GDAL dev team,
> I am not sure if I am following a wrong approach, if there is an issue
> with the osm driver, the distributed OSM file or if the error message
> is just ambiguous and could be improved.
> I used ogr2ogr to select 12 keys to be extracted as polygons along
> with something around 40 conditions. The algorithm had worked well on
> a tiny OSM file with the city of Munich so tested it I on a small
> sample area of 1°x1° on the global planet OSM file:
> ogr2ogr -spat 10 45 11 46 -f gpkg c:\daten\osm_planet\1x1.gpkg
> c:\daten\osm_planet\planet-220502.osm.pbf multipolygons -select
> "name,aeroway,amenity,building,historic,landuse,leisure,military,office,tourism,shop,landuse
> " -where @ogr2ogr_condition.txt
> The first 70% were reached after one hour but then the process slowed
> down and after 19 hours I got an error message:
> 0...10...20...30...40...50...60...70...80...90.ERROR 1: Too many
> If this is because one or more features exceed the maximum amount of
> doable keys, is the officially by OSM distributed file wrong or too
> large to be processed by ogr2ogr or what's the matter? I tried to read
> the relevant source code file where the error message occurs but it's
> too cryptic to me.
> Content of ogr2ogr_condition.txt for the sake of completeness:
> historic is null and
> office is not null or
> building='hotel' or
> building='hospital' or
> building='apartments' or
> building='barracks' or
> building='dormitory' or
> building='warehouse' or
> building='monastery' or
> building='public' or
> building='hangar' or
> tourism='guest_house' or
> tourism='apartment' or
> tourism='hostel' or
> tourism='museum' or
> tourism='gallery' or
> tourism='motel' or
> tourism='hotel' or
> amenity='university' or
> amenity='research_institute' or
> amenity='social_facility' or
> amenity='school' or
> amenity='kindergarten' or
> amenity='kindergarden' or
> amenity='exhibition centre' or
> amenity='student_accommodation' or
> amenity='library' or
> amenity='clinic' or
> amenity='hospital' or
> amenity='public_building' or
> amenity='concert_hall' or
> amenity='prison' or
> amenity='theatre' or
> amenity='courthouse' or
> aeroway='terminal' or
> shop='mall' or
> military='base' or
> military='barracks' or
> military='office' or
> landuse='education' or
> landuse='commercial' or
> landuse='industrial'
> I’d be grateful for any hints and glad to contribute to any error
> message improval if indicated.
> Kind regards, Tobias Schmetzer
> ZAE Bayern
> Tobias Schmetzer, Dipl. Ing.
> Wissenschaftlicher Mitarbeiter Systementwicklung | Scientific Staff
> Member Systems Engineering
> Bereich Energiespeicherung| Division Energy Storage
> Walther-Meißner-Str. 6
> 85748 Garching
> Tel.: +49 89 329442-65
> Fax: +49 89 329442-12
> tobias.schmetzer at zae-bayern.de<mailto:tobias.schmetzer at zae-bayern.de>
> http://www.zae-bayern.de<https://pulsar.zae-bayern.de/,DanaInfo=eur06.safelinks.protection.outlook.com,SSL+?url=http%3A%2F%2Fwww.zae-bayern.de%2F&data=05%7C01%7Cjukka.rahkonen%40maanmittauslaitos.fi%7Cb03bc6c9f5b542ed51ff08da34b64dd1%7Cc4f8a63255804a1c92371d5a571b71fa%7C0%7C1%7C637880254860879658%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000%7C%7C%7C&sdata=xkCacr5vK0eKSDXGyhCzWrhN5ckc%2BYNEVWPcChPcs2Y%3D&reserved=0>
> ZAE Bayern - Bayerisches Zentrum für Angewandte Energieforschung e. V.
> Vorstand/Board:
> Prof. Dr. Hartmut Spliethoff (Vorsitzender/Chairman),
> Prof. Dr. Vladimir Dyakonov
> Sitz/Registered Office: Würzburg
> Registergericht/Register Court: Amtsgericht Würzburg
> Registernummer/Register Number: VR 1386
> Sämtliche Willenserklärungen, z. B. Angebote, Aufträge, Anträge und
> Verträge, sind für das ZAE Bayern nur in schriftlicher und
> ordnungsgemäß unterschriebener Form rechtsverbindlich. Diese E-Mail
> ist ausschließlich zur Nutzung durch den/die vorgenannten Empfänger
> bestimmt. Jegliche unbefugte Offenbarung, Nutzung oder Verbreitung,
> sei es insgesamt oder teilweise, ist untersagt. Sollten Sie diese
> E-Mail irrtümlich erhalten haben, benachrichtigen Sie bitte
> unverzüglich den Absender und löschen Sie diese E-Mail.
> Any declarations of intent, such as quotations, orders, applications
> and contracts, are legally binding for ZAE Bayern only if expressed in
> a written and duly signed form. This e-mail is intended solely for use
> by the recipient(s) named above. Any unauthorised disclosure, use or
> dissemination, whether in whole or in part, is prohibited. If you have
> received this e-mail in error, please notify the sender immediately
> and delete this e-mail.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220513/184037e8/attachment-0001.htm>
