[gdal-dev] Normalized/laundered field names
Even Rouault
even.rouault at spatialys.com
Fri May 13 10:27:32 PDT 2022
this comes from https://trac.osgeo.org/gdal/ticket/4458
The full list of laundered field name is at
https://github.com/OSGeo/gdal/blob/94625cba3367c5709175e5b7a037febe737742f0/ogr/ogrsf_frmts/filegdb/FGdbUtils.cpp#L522
There's a hidden -lco LAUNDER_RESERVED_KEYWORDS=FALSE layer creation
option (will only work if you just created the layer. to be opposed to
updating an existing one) to disable this, but this might apparently
cause issues with ArcMap. At least it did in the past
Even
Le 13/05/2022 à 19:11, adamgutonski via gdal-dev a écrit :
> Hello,
> I am attempting to create an ogr.OFTDateTime field named "date",
> within a file geodatabase table. However anytime a field definition
> is created with the name "date", once the layer tries to create the
> field, I get receive a warning:
> *Warning 6: Normalized/laundered field name: 'date' to 'date_'*
> Why does this field need to be normalized? Is there anyway to
> suppress this warning and retain the "date" string that is expected as
> the field name? Are there other field names besides *date* that will
> always be normalized?
> Below is my code snippet:
> /field_defn = ogr.FieldDefn("date", ogr.OFTDateTime)/
> /layer.CreateField(field_defn)/
> Thank you for your time as always!
> Sincerely,
> Adam Gutonski
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220513/412384b6/attachment.htm>
