[gdal-dev] Ignoring index in OGR2OGR
Even Rouault
even.rouault at spatialys.com
Mon May 16 13:19:35 PDT 2022
Felipe,
If you look at https://gdal.org/drivers/vector/mysql.html, you can see a
SPATIAL_INDEX layer creation being mentioned.
So try adding -lco SPATIAL_INDEX=NO to your ogr2ogr command line
Even
Le 16/05/2022 à 22:13, Felipe Matas via gdal-dev a écrit :
> Hi, I'm trying to use Dolt (a new db) with spatial data, it works with
> a MySQL syntax/core, so I'm able to use ogr2ogr to export data to the
> database, well half of it, the db actually don't support spatial
> index, and ogr2ogr use a spatial index, is there a way to upload a
> spatial file without set a spatial index with ogr2ogr? I check the
> doc, sadly I wasn't able get an answer.
> Thx.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220516/be8e6f52/attachment.htm>
