[gdal-dev] ogr2ogr Postgres upload performance
Alexandre Gacon
alexandre.gacon at gmail.com
Mon May 23 06:03:47 PDT 2022
Hello,
I am using ogr2ogr to upload data from several geopackages to a postgis
database. Some tables contain thousands of rows (buildings for example).
The import of the first file is quite fast (tables are created for the
first file so PG_USE_COPY is used) but the following file is much slower
(using INSERT instead of COPY).
How could I data insertion for the other files? Force PG_USE_COPY ?
Increase the value of GT ? Postpone spatial index creation ?
Should I concatenate all the geopackages first and then insert the data in
Postgis?
Thank you for your help
Alexandre Gacon
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220523/28ad3cf9/attachment.htm>
