[gdal-dev] ogr2ogr Postgres upload performance
Alexandre Gacon
alexandre.gacon at gmail.com
Fri May 27 07:58:18 PDT 2022
Hi Jukka,
The problem is not related to a multi-table geopackage but to a set of
geopackages with several tables in each : the first geopackage creates the
tables so it can use the PG_USE_COPY but for the other files it has to go
with the INSERT.
Regards
Alexandre
Le ven. 27 mai 2022 à 15:12, Rahkonen Jukka <
jukka.rahkonen at maanmittauslaitos.fi> a écrit :
> Hi,
> If the problem is that PG_USE_COPY is applied only to the first layer of
> the multi-table GeoPackage then I would make a test by writing a separate
> ogr2ogr command for each layer.
> -Jukka Rahkonen-
> *Lähettäjä:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta *Alexandre
> Gacon
> *Lähetetty:* maanantai 23. toukokuuta 2022 17.39
> *Vastaanottaja:* Jan Heckman <jan.heckman at gmail.com>
> *Kopio:* gdal-dev <gdal-dev at lists.osgeo.org>
> *Aihe:* Re: [gdal-dev] ogr2ogr Postgres upload performance
> I will try this way. To turn of SI creation : *SPATIAL_INDEX*=NONE
> Le lun. 23 mai 2022 à 15:15, Jan Heckman <jan.heckman at gmail.com> a écrit :
> Perhaps the spatial index update (in de DB) slows the insertion.
> It might be more efficient to not create the SI in the first run,
> then insert more rows and create the SI after all is done.
> I don't know how to turn off SI creation in the command line.
> On Mon, May 23, 2022 at 3:04 PM Alexandre Gacon <alexandre.gacon at gmail.com>
> wrote:
> Hello,
> I am using ogr2ogr to upload data from several geopackages to a postgis
> database. Some tables contain thousands of rows (buildings for example).
> The import of the first file is quite fast (tables are created for the
> first file so PG_USE_COPY is used) but the following file is much slower
> (using INSERT instead of COPY).
> How could I data insertion for the other files? Force PG_USE_COPY ?
> Increase the value of GT ? Postpone spatial index creation ?
> Should I concatenate all the geopackages first and then insert the data in
> Postgis?
> Thank you for your help
> Alexandre Gacon
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> <https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fgdal-dev&data=05%7C01%7Cjukka.rahkonen%40maanmittauslaitos.fi%7C6fa46f068e26430b7f9908da3cca0f7a%7Cc4f8a63255804a1c92371d5a571b71fa%7C0%7C0%7C637889135792134784%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=%2Bmpy0HNtP0mb%2FzvSpD4E9U0Cipge3NviqQs%2B7D6hZcQ%3D&reserved=0>
> Alexandre Gacon
Alexandre Gacon
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220527/eaa6b394/attachment-0001.htm>
