[gdal-dev] Problems with Sentinel 1 calibrated bands
Even Rouault
even.rouault at spatialys.com
Sun May 29 10:46:53 PDT 2022
Stefan,
candidate fix in https://github.com/OSGeo/gdal/pull/5812
Even
Le 29/05/2022 à 16:55, Stefan Gofferje a écrit :
> Hi,
> I'm trying to access the calibrated bands of a Sentinel 1 GRDH dataset
> with gdal. Gdalinfo lists the bands but if I try to access any other
> than the UNCALIB bands, I get "ERROR 4: Measurement bands not found."
> What am I missing? I tried with gdal 3.4.2, 3.5.0 and 3.6.0-dev
> through docker.
> Some outputs...
> docker run --rm -v $(pwd):/share osgeo/gdal gdalinfo
> /share/S1A_IW_GRDH_1SDV_20220529T045822_20220529T045847_043421_052F5A_01B5.SAFE
> Driver: SAFE/Sentinel-1 SAR SAFE Product
> Files:
> /share/S1A_IW_GRDH_1SDV_20220529T045822_20220529T045847_043421_052F5A_01B5.SAFE/manifest.safe
> /share/S1A_IW_GRDH_1SDV_20220529T045822_20220529T045847_043421_052F5A_01B5.SAFE/annotation/s1a-iw-grd-vh-20220529t045822-20220529t045847-043421-052f5a-002.xml
> /share/S1A_IW_GRDH_1SDV_20220529T045822_20220529T045847_043421_052F5A_01B5.SAFE/annotation/calibration/calibration-s1a-iw-grd-vh-20220529t045822-20220529t045847-043421-052f5a-002.xml
> /share/S1A_IW_GRDH_1SDV_20220529T045822_20220529T045847_043421_052F5A_01B5.SAFE/measurement/s1a-iw-grd-vh-20220529t045822-20220529t045847-043421-052f5a-002.tiff
> /share/S1A_IW_GRDH_1SDV_20220529T045822_20220529T045847_043421_052F5A_01B5.SAFE/annotation/s1a-iw-grd-vv-20220529t045822-20220529t045847-043421-052f5a-001.xml
> /share/S1A_IW_GRDH_1SDV_20220529T045822_20220529T045847_043421_052F5A_01B5.SAFE/annotation/calibration/calibration-s1a-iw-grd-vv-20220529t045822-20220529t045847-043421-052f5a-001.xml
> /share/S1A_IW_GRDH_1SDV_20220529T045822_20220529T045847_043421_052F5A_01B5.SAFE/measurement/s1a-iw-grd-vv-20220529t045822-20220529t045847-043421-052f5a-001.tiff
> Size is 26589, 16669
> GCP Projection =
> GEOGCRS["WGS 84",
> DATUM["World Geodetic System 1984",
> ELLIPSOID["WGS 84",6378137,298.257223563,
> LENGTHUNIT["metre",1]]],
> PRIMEM["Greenwich",0,
> ANGLEUNIT["degree",0.0174532925199433]],
> CS[ellipsoidal,2],
> AXIS["geodetic latitude (Lat)",north,
> ORDER[1],
> AXIS["geodetic longitude (Lon)",east,
> ORDER[2],
> ID["EPSG",4326]]
> Data axis to CRS axis mapping: 2,1
> GCP[ 0]: Id=1, Info=
> (0,0) -> (24.2989206702428,62.0656022234132,106.994836739264)
> GCP[ 1]: Id=2, Info=
> (1330,0) -> (24.0509518769921,62.092607582198,107.99461737182)
> GCP[ 2]: Id=3, Info=
> (2660,0) ->
> (23.8018857113942,62.1192375089563,130.993210118264)
> GCP[ 3]: Id=4, Info=
> (3990,0) ->
> (23.5515888146731,62.1455011932857,182.990143274888)
> GCP[ 4]: Id=5, Info=
> (5320,0) -> (23.3031194363654,62.1710829077887,158.99125385657)
> GCP[ 5]: Id=6, Info=
> (6650,0) ->
> (23.0537757892362,62.1962643369359,149.991561236791)
> GCP[ 6]: Id=7, Info=
> (7980,0) -> (22.8035517712763,62.221042562019,157.990891823545)
> GCP[ 7]: Id=8, Info=
> (9310,0) ->
> (22.5534256638639,62.2453209124973,146.991352031939)
> GCP[ 8]: Id=9, Info=
> (10640,0) ->
> (22.3022807176232,62.269206229413,159.990369951353)
> GCP[ 9]: Id=10, Info=
> (11970,0) ->
> (22.0514692746566,62.292570402378,143.991174837574)
> GCP[ 10]: Id=11, Info=
> (13300,0) ->
> (21.8010816405873,62.3154091263228,92.9942450607195)
> GCP[ 11]: Id=12, Info=
> (14630,0) ->
> (21.5501579479435,62.3378106590907,45.997171105817)
> GCP[ 12]: Id=13, Info=
> (15960,0) ->
> (21.2986715983706,62.3597758751047,4.99980543088168)
> GCP[ 13]: Id=14, Info=
> (17290,0) ->
> (21.0459841132435,62.3813565495259,0.000123757869005203)
> GCP[ 14]: Id=15, Info=
> (18620,0) ->
> (20.792828393878,62.402487327609,0.000114256516098976)
> GCP[ 15]: Id=16, Info=
> (19950,0) ->
> (20.5393238488582,62.4231576641046,0.000105424784123898)
> GCP[ 16]: Id=17, Info=
> (21280,0) ->
> (20.2854771640073,62.4433664512174,9.7726471722126e-05)
> GCP[ 17]: Id=18, Info=
> (22610,0) ->
> (20.0312951592633,62.4631127047608,9.00477170944214e-05)
> GCP[ 18]: Id=19, Info=
> (23940,0) ->
> (19.7767847704349,62.4823955369184,8.2898885011673e-05)
> GCP[ 19]: Id=20, Info=
> (25270,0) ->
> (19.5219529872478,62.5012139978368,7.62529671192169e-05)
> GCP[ 20]: Id=21, Info=
> (26588,0) ->
> (19.2691103344065,62.5194036480545,7.01239332556725e-05)
> GCP[ 21]: Id=22, Info=
> (0,2001) -> (24.2080543659278,61.888257050717,152.992458630353)
> GCP[ 22]: Id=23, Info=
> (1330,2001) ->
> (23.9630267998469,61.9150002816116,105.994716337882)
> GCP[ 23]: Id=24, Info=
> (2660,2001) ->
> (23.7140686489102,61.9416776332821,171.990981132723)
> GCP[ 24]: Id=25, Info=
> (3990,2001) ->
> (23.4667125840941,61.9676939626964,172.99068558123)
> GCP[ 25]: Id=26, Info=
> (5320,2001) ->
> (23.2196999899106,61.9931887813232,146.991923337802)
> GCP[ 26]: Id=27, Info=
> (6650,2001) ->
> (22.9715465445242,62.0183139399728,145.991782669909)
> GCP[ 27]: Id=28, Info=
> (7980,2001) ->
> (22.7229331502079,62.0429980220244,146.991530948319)
> GCP[ 28]: Id=29, Info=
> (9310,2001) ->
> (22.4743334516797,62.0671946988188,131.992245730944)
> GCP[ 29]: Id=30, Info=
> (10640,2001) ->
> (22.2242950677779,62.091042116942,157.99048130773)
> GCP[ 30]: Id=31, Info=
> (11970,2001) ->
> (21.9758004617246,62.1142596195014,105.9935412677)
> GCP[ 31]: Id=32, Info=
> (13300,2001) ->
> (21.7265499675309,62.1370646627628,66.9958932409063)
> GCP[ 32]: Id=33, Info=
> (14630,2001) ->
> (21.4767405276822,62.159437251607,33.997944701463)
> GCP[ 33]: Id=34, Info=
> (15960,2001) ->
> (21.2265496807387,62.1813604968731,0.000134445726871491)
> GCP[ 34]: Id=35, Info=
> (17290,2001) ->
> (20.9752203801235,62.2028973437146,0.000124219805002212)
> GCP[ 35]: Id=36, Info=
> (18620,2001) ->
> (20.7235412112952,62.2239780739968,0.000114718452095985)
> GCP[ 36]: Id=37, Info=
> (19950,2001) ->
> (20.471518649791,62.2446016370407,0.00010587926954031)
> GCP[ 37]: Id=38, Info=
> (21280,2001) ->
> (20.2191593108756,62.2647671187505,9.81753692030907e-05)
> GCP[ 38]: Id=39, Info=
> (22610,2001) ->
> (19.9664698749843,62.2844735600224,9.0484507381916e-05)
> GCP[ 39]: Id=40, Info=
> (23940,2001) ->
> (19.7134570882057,62.3037199620391,8.33338126540184e-05)
> GCP[ 40]: Id=41, Info=
> (25270,2001) ->
> (19.4601277978319,62.322505394488,7.66757875680923e-05)
> GCP[ 41]: Id=42, Info=
> (26588,2001) ->
> (19.2087787980604,62.3406657906346,7.05337151885033e-05)
> GCP[ 42]: Id=43, Info=
> (0,4002) ->
> (24.1197204341443,61.7106818749531,145.992810498923)
> GCP[ 43]: Id=44, Info=
> (1330,4002) ->
> (23.8756019590733,61.7373845579929,114.994233490899)
> GCP[ 44]: Id=45, Info=
> (2660,4002) ->
> (23.629496513455,61.7638184263628,133.993030846119)
> GCP[ 45]: Id=46, Info=
> (3990,4002) ->
> (23.383879517774,61.7897162575957,122.993449121714)
> GCP[ 46]: Id=47, Info=
> (5320,4002) ->
> (23.1382499505042,61.8151337816392,96.9947503795847)
> GCP[ 47]: Id=48, Info=
> (6650,4002) ->
> (22.8909478214768,61.8402388898265,115.993511782959)
> GCP[ 48]: Id=49, Info=
> (7980,4002) ->
> (22.6437523205496,61.8648489469681,116.993295862339)
> GCP[ 49]: Id=50, Info=
> (9310,4002) ->
> (22.3967018863301,61.888962789262,96.9943484319374)
> GCP[ 50]: Id=51, Info=
> (10640,4002) ->
> (22.1490366146869,61.9126545067561,84.9949591299519)
> GCP[ 51]: Id=52, Info=
> (11970,4002) ->
> (21.9009023136425,61.9359087053143,75.9954124391079)
> GCP[ 52]: Id=53, Info=
> (13300,4002) ->
> (21.652923134121,61.9586681167251,43.9973542811349)
> GCP[ 53]: Id=54, Info=
> (14630,4002) ->
> (21.4046289406696,61.9809767003838,7.99962751474231)
> GCP[ 54]: Id=55, Info=
> (15960,4002) ->
> (21.1553089651544,62.0028955604834,0.000134930945932865)
> GCP[ 55]: Id=56, Info=
> (17290,4002) ->
> (20.905454247964,62.0243790224046,0.000124700367450714)
> GCP[ 56]: Id=57, Info=
> (18620,4002) ->
> (20.6552540328187,62.0454097630213,0.000115189701318741)
> GCP[ 57]: Id=58, Info=
> (19950,4002) ->
> (20.4047148291392,62.0659869784385,0.000106345862150192)
> GCP[ 58]: Id=59, Info=
> (21280,4002) ->
> (20.153843113437,62.0861095766864,9.86345112323761e-05)
> GCP[ 59]: Id=60, Info=
> (22610,4002) ->
> (19.9026454920829,62.1057766084131,9.09380614757538e-05)
> GCP[ 60]: Id=61, Info=
> (23940,4002) ->
> (19.6511286654558,62.1249871880393,8.37771221995354e-05)
> GCP[ 61]: Id=62, Info=
> (25270,4002) ->
> (19.3992993928115,62.1437404053763,7.71107152104378e-05)
> GCP[ 62]: Id=63, Info=
> (26588,4002) ->
> (19.1494407215976,62.1618722608357,7.09602609276772e-05)
> GCP[ 63]: Id=64, Info=
> (0,6003) -> (24.0325012315285,61.5330304633765,128.9936801726)
> GCP[ 64]: Id=65, Info=
> (1330,6003) ->
> (23.7896716099477,61.5596522776937,99.9950212463737)
> GCP[ 65]: Id=66, Info=
> (2660,6003) ->
> (23.5447560051294,61.5860196291082,124.993511032313)
> GCP[ 66]: Id=67, Info=
> (3990,6003) ->
> (23.3006011058715,61.6118254038051,110.994107959792)
> GCP[ 67]: Id=68, Info=
> (5320,6003) ->
> (23.0557914330143,61.6372206818696,104.994289906695)
> GCP[ 68]: Id=69, Info=
> (6650,6003) ->
> (22.8106529143157,61.6621706489545,95.994664631784)
> GCP[ 69]: Id=70, Info=
> (7980,6003) ->
> (22.5651589780168,61.6866778084148,84.9951831735671)
> GCP[ 70]: Id=71, Info=
> (9310,6003) ->
> (22.3192360197291,61.7107488327685,74.9956707088277)
> GCP[ 71]: Id=72, Info=
> (10640,6003) ->
> (22.0734121288682,61.7343330906643,44.9974154364318)
> GCP[ 72]: Id=73, Info=
> (11970,6003) ->
> (21.8266212732184,61.7575314633754,37.9977893009782)
> GCP[ 73]: Id=74, Info=
> (13300,6003) ->
> (21.5800385532558,61.7802334812188,5.99977553077042)
> GCP[ 74]: Id=75, Info=
> (14630,6003) ->
> (21.3324649039203,61.8025482169815,0.000146404840052128)
> GCP[ 75]: Id=76, Info=
> (15960,6003) ->
> (21.0843982280882,61.8244283853141,0.000135401263833046)
> GCP[ 76]: Id=77, Info=
> (17290,6003) ->
> (20.8359848057792,61.8458602559811,0.000125167891383171)
> GCP[ 77]: Id=78, Info=
> (18620,6003) ->
> (20.5872309113812,61.866842894818,0.000115653499960899)
> GCP[ 78]: Id=79, Info=
> (19950,6003) ->
> (20.3381428583675,61.8873752707486,0.000106805004179478)
> GCP[ 79]: Id=80, Info=
> (21280,6003) ->
> (20.088727080359,61.9074564761268,9.90899279713631e-05)
> GCP[ 80]: Id=81, Info=
> (22610,6003) ->
> (19.8389900478774,61.9270855121271,9.13823023438454e-05)
> GCP[ 81]: Id=82, Info=
> (23940,6003) ->
> (19.5889383686463,61.9462615746542,8.42111185193062e-05)
> GCP[ 82]: Id=83, Info=
> (25270,6003) ->
> (19.3385786167154,61.9649835774847,7.75400549173355e-05)
> GCP[ 83]: Id=84, Info=
> (26588,6003) ->
> (19.0901804823776,61.9830880101717,7.13765621185303e-05)
> GCP[ 84]: Id=85, Info=
> (0,8004) -> (23.945773466476,61.3553704292709,120.99408631213)
> GCP[ 85]: Id=86, Info=
> (1330,8004) ->
> (23.7033431883923,61.3820069271569,122.993795001879)
> GCP[ 86]: Id=87, Info=
> (2660,8004) ->
> (23.4616583398656,61.4080881127824,85.9956226982176)
> GCP[ 87]: Id=88, Info=
> (3990,8004) ->
> (23.2186934738322,61.433831750506,76.9959917999804)
> GCP[ 88]: Id=89, Info=
> (5320,8004) ->
> (22.9741780393663,61.4592598286823,108.994055869989)
> GCP[ 89]: Id=90, Info=
> (6650,8004) ->
> (22.7308550149439,61.4840892394681,83.9953555390239)
> GCP[ 90]: Id=91, Info=
> (7980,8004) ->
> (22.4868432268077,61.5085141792756,68.9961262820289)
> GCP[ 91]: Id=92, Info=
> (9310,8004) ->
> (22.242351807109,61.5325120397479,56.9967542113736)
> GCP[ 92]: Id=93, Info=
> (10640,8004) ->
> (21.9977142302178,61.5560501976351,34.9980288334191)
> GCP[ 93]: Id=94, Info=
> (11970,8004) ->
> (21.7526787048724,61.5791527238178,12.9993557753041)
> GCP[ 94]: Id=95, Info=
> (13300,8004) ->
> (21.5070445912198,61.6018371708819,0.000158727169036865)
> GCP[ 95]: Id=96, Info=
> (14630,8004) ->
> (21.2607462031648,61.6241074193865,0.000146878883242607)
> GCP[ 96]: Id=97, Info=
> (15960,8004) ->
> (21.0140998240437,61.6459337007027,0.000135870650410652)
> GCP[ 97]: Id=98, Info=
> (17290,8004) ->
> (20.7671115623751,61.6673150797835,0.000125633552670479)
> GCP[ 98]: Id=99, Info=
> (18620,8004) ->
> (20.5197875816205,61.6882505758383,0.000116118229925633)
> GCP[ 99]: Id=100, Info=
> (19950,8004) ->
> (20.2721341220771,61.7087392236208,0.000107264146208763)
> GCP[100]: Id=101, Info=
> (21280,8004) ->
> (20.0241574546547,61.7287799522812,9.95416194200516e-05)
> GCP[101]: Id=102, Info=
> (22610,8004) ->
> (19.7758640328029,61.748372011583,9.18274745345116e-05)
> GCP[102]: Id=103, Info=
> (23940,8004) ->
> (19.5272602710408,61.7675143688249,8.46460461616516e-05)
> GCP[103]: Id=104, Info=
> (25270,8004) ->
> (19.278352711222,61.7862061771427,7.79656693339348e-05)
> GCP[104]: Id=105, Info=
> (26588,8004) ->
> (19.031397691998,61.8042839336302,7.17965885996819e-05)
> GCP[105]: Id=106, Info=
> (0,10005) ->
> (23.8603483488193,61.177611337006,95.9953740928322)
> GCP[106]: Id=107, Info=
> (1330,10005) ->
> (23.61888087472,61.2042025304336,108.9945312161)
> GCP[107]: Id=108, Info=
> (2660,10005) ->
> (23.3768597854358,61.2303790109944,127.993332424201)
> GCP[108]: Id=109, Info=
> (3990,10005) ->
> (23.1354148146546,61.2560210410327,113.993927174248)
> GCP[109]: Id=110, Info=
> (5320,10005) ->
> (22.8939075793176,61.281199297591,86.9953014012426)
> GCP[110]: Id=111, Info=
> (6650,10005) ->
> (22.6514857990923,61.3060010064546,77.9956991737708)
> GCP[111]: Id=112, Info=
> (7980,10005) ->
> (22.4092898285924,61.3303098869508,44.997546303086)
> GCP[112]: Id=113, Info=
> (9310,10005) ->
> (22.1660912457114,61.3542478545845,34.998082277365)
> GCP[113]: Id=114, Info=
> (10640,10005) ->
> (21.9225108110462,61.3777517640695,24.9986436422914)
> GCP[114]: Id=115, Info=
> (11970,10005) ->
> (21.6781758196299,61.4008557149015,30.9982244381681)
> GCP[115]: Id=116, Info=
> (13300,10005) ->
> (21.4343475186385,61.4234421376293,0.000159192830324173)
> GCP[116]: Id=117, Info=
> (14630,10005) ->
> (21.1894351222574,61.4456571513278,0.000147342681884766)
> GCP[117]: Id=118, Info=
> (15960,10005) ->
> (20.9441801367313,61.4674314640818,0.000136332586407661)
> GCP[118]: Id=119, Info=
> (17290,10005) ->
> (20.6985884994464,61.4887640304182,0.000126097351312637)
> GCP[119]: Id=120, Info=
> (18620,10005) ->
> (20.4526662745944,61.509653945748,0.000116573646664619)
> GCP[120]: Id=121, Info=
> (19950,10005) ->
> (20.2064195550724,61.5301001991144,0.000107714906334877)
> GCP[121]: Id=122, Info=
> (21280,10005) ->
> (19.959854551448,61.5501019168871,9.99858602881432e-05)
> GCP[122]: Id=123, Info=
> (22610,10005) ->
> (19.7129775017057,61.5696581246356,9.22689214348793e-05)
> GCP[123]: Id=124, Info=
> (23940,10005) ->
> (19.4657947500622,61.5887679721648,8.50800424814224e-05)
> GCP[124]: Id=125, Info=
> (25270,10005) ->
> (19.2183126905633,61.6074305841907,7.83894211053848e-05)
> GCP[125]: Id=126, Info=
> (26588,10005) ->
> (18.9727746213921,61.6254827319239,7.22110271453857e-05)
> GCP[126]: Id=127, Info=
> (0,12006) ->
> (23.7739113422044,61.0000082925118,126.993760735728)
> GCP[127]: Id=128, Info=
> (1330,12006) ->
> (23.5344286180648,61.0264394606908,118.993992947973)
> GCP[128]: Id=129, Info=
> (2660,12006) ->
> (23.2945875783768,61.0524413620411,108.994359689765)
> GCP[129]: Id=130, Info=
> (3990,12006) ->
> (23.0545595378144,61.0779956579564,90.9952022740617)
> GCP[130]: Id=131, Info=
> (5320,12006) ->
> (22.8139470308714,61.1031439525327,78.995751991868)
> GCP[131]: Id=132, Info=
> (6650,12006) ->
> (22.5725617134713,61.1279034775919,80.9955197358504)
> GCP[132]: Id=133, Info=
> (7980,12006) ->
> (22.3315254543538,61.152160296568,54.9969495311379)
> GCP[133]: Id=134, Info=
> (9310,12006) ->
> (22.0898560340223,61.1760134218892,37.997898504138)
> GCP[134]: Id=135, Info=
> (10640,12006) ->
> (21.8476302059831,61.1994535289686,27.998457049951)
> GCP[135]: Id=136, Info=
> (11970,12006) ->
> (21.6051292815324,61.2224526825595,13.9992919005454)
> GCP[136]: Id=137, Info=
> (13300,12006) ->
> (21.3622605326795,61.2450193029368,0.000159650109708309)
> GCP[137]: Id=138, Info=
> (14630,12006) ->
> (21.1187182908208,61.2671801728785,0.000147805549204349)
> GCP[138]: Id=139, Info=
> (15960,12006) ->
> (20.8748386335332,61.2889035169594,0.000136794522404671)
> GCP[139]: Id=140, Info=
> (17290,12006) ->
> (20.6306273874715,61.3101883088216,0.000126553699374199)
> GCP[140]: Id=141, Info=
> (18620,12006) ->
> (20.3860905013767,61.3310336581122,0.000117029063403606)
> GCP[141]: Id=142, Info=
> (19950,12006) ->
> (20.1412339507093,61.3514385678511,0.000108165666460991)
> GCP[142]: Id=143, Info=
> (21280,12006) ->
> (19.8960638260111,61.3714021781337,9.99076291918755e-05)
> GCP[143]: Id=144, Info=
> (22610,12006) ->
> (19.6505862628296,61.3909235841447,9.27085056900978e-05)
> GCP[144]: Id=145, Info=
> (23940,12006) ->
> (19.40480744352,61.4100018411796,8.55131074786186e-05)
> GCP[145]: Id=146, Info=
> (25270,12006) ->
> (19.1587336311576,61.4286360680341,7.88131728768349e-05)
> GCP[146]: Id=147, Info=
> (26588,12006) ->
> (18.9145952803906,61.4466634000049,7.26226717233658e-05)
> GCP[147]: Id=148, Info=
> (0,14007) ->
> (23.6900365293308,60.8221646898238,99.9951552636921)
> GCP[148]: Id=149, Info=
> (1330,14007) ->
> (23.4513685675693,60.8485663996166,106.994624823332)
> GCP[149]: Id=150, Info=
> (2660,14007) ->
> (23.2127298439685,60.8744991106713,99.9948440110311)
> GCP[150]: Id=151, Info=
> (3990,14007) ->
> (22.9741685625109,60.8999596366724,75.9960338585079)
> GCP[151]: Id=152, Info=
> (5320,14007) ->
> (22.7342025641232,60.9251030791767,87.9952338002622)
> GCP[152]: Id=153, Info=
> (6650,14007) ->
> (22.4945419941446,60.9497496602415,74.9958644825965)
> GCP[153]: Id=154, Info=
> (7980,14007) ->
> (22.2548238724715,60.97393886608,48.9973031524569)
> GCP[154]: Id=155, Info=
> (9310,14007) ->
> (22.0141073209515,60.9977636677237,46.9973503416404)
> GCP[155]: Id=156, Info=
> (10640,14007) ->
> (21.7733208717469,61.0211312019295,32.9981463970617)
> GCP[156]: Id=157, Info=
> (11970,14007) ->
> (21.5321881095603,61.0440684147328,17.9990394823253)
> GCP[157]: Id=158, Info=
> (13300,14007) ->
> (21.2907598979326,61.0665702378496,0.000160110183060169)
> GCP[158]: Id=159, Info=
> (14630,14007) ->
> (21.0485713507538,61.0886780762289,0.000148262828588486)
> GCP[159]: Id=160, Info=
> (15960,14007) ->
> (20.8060504122105,61.1103515405646,0.000137250870466232)
> GCP[160]: Id=161, Info=
> (17290,14007) ->
> (20.5632028015279,61.1315896181879,0.000127012841403484)
> GCP[161]: Id=162, Info=
> (18620,14007) ->
> (20.3200343347319,61.1523913714526,0.000117480754852295)
> GCP[162]: Id=163, Info=
> (19950,14007) ->
> (20.0765509415748,61.1727559991541,0.00010861549526453)
> GCP[163]: Id=164, Info=
> (21280,14007) ->
> (19.8327585304691,61.192682472025,0.000100354664027691)
> GCP[164]: Id=165, Info=
> (22610,14007) ->
> (19.5886631226454,61.2121699027424,9.31425020098686e-05)
> GCP[165]: Id=166, Info=
> (23940,14007) ->
> (19.3442708185318,61.2312174668447,8.59443098306656e-05)
> GCP[166]: Id=167, Info=
> (25270,14007) ->
> (19.0995877646519,61.2498243141904,7.92341306805611e-05)
> GCP[167]: Id=168, Info=
> (26588,14007) ->
> (18.8568316230963,61.2678275943937,7.30399042367935e-05)
> GCP[168]: Id=169, Info=
> (0,16008) ->
> (23.6059797026375,60.6443836941483,101.995045578107)
> GCP[169]: Id=170, Info=
> (1330,16008) ->
> (23.3687438677912,60.6706867391765,103.99477851484)
> GCP[170]: Id=171, Info=
> (2660,16008) ->
> (23.1313570096156,60.6965441710611,97.994947350584)
> GCP[171]: Id=172, Info=
> (3990,16008) ->
> (22.8938571954131,60.7219527672419,81.9956942740828)
> GCP[172]: Id=173, Info=
> (5320,16008) ->
> (22.656007580055,60.7469381124485,63.9965992895886)
> GCP[173]: Id=174, Info=
> (6650,16008) ->
> (22.41697160534,60.7715846741416,75.9958016499877)
> GCP[174]: Id=175, Info=
> (7980,16008) ->
> (22.178329818954,60.7957297739498,58.9967048242688)
> GCP[175]: Id=176, Info=
> (9310,16008) ->
> (21.9394283196346,60.8194410965588,36.9979549208656)
> GCP[176]: Id=177, Info=
> (10640,16008) ->
> (21.7000482253593,60.8427397033859,18.9990110993385)
> GCP[177]: Id=178, Info=
> (11970,16008) ->
> (21.4599722583639,60.8656446600893,14.9992277706042)
> GCP[178]: Id=179, Info=
> (13300,16008) ->
> (21.219779011151,60.8881003051578,1.00009655207396)
> GCP[179]: Id=180, Info=
> (14630,16008) ->
> (20.9789483069483,60.9101542752511,0.000148721970617771)
> GCP[180]: Id=181, Info=
> (15960,16008) ->
> (20.7377675123388,60.9317790556391,0.000137710012495518)
> GCP[181]: Id=182, Info=
> (17290,16008) ->
> (20.4962649307966,60.9529715733518,0.000127464532852173)
> GCP[182]: Id=183, Info=
> (18620,16008) ->
> (20.2544462855551,60.9737309610258,0.000117935240268707)
> GCP[183]: Id=184, Info=
> (19950,16008) ->
> (20.0123173246984,60.9940562488306,0.00010906346142292)
> GCP[184]: Id=185, Info=
> (21280,16008) ->
> (19.769883908157,61.0139466082006,0.000100798904895782)
> GCP[185]: Id=186, Info=
> (22610,16008) ->
> (19.5271519115539,61.0334010901856,9.35820862650871e-05)
> GCP[186]: Id=187, Info=
> (23940,16008) ->
> (19.2841273213243,61.0524189019843,8.63727182149887e-05)
> GCP[187]: Id=188, Info=
> (25270,16008) ->
> (19.0408161556565,61.0709991873323,7.96578824520111e-05)
> GCP[188]: Id=189, Info=
> (26588,16008) ->
> (18.7994235463323,61.0889793839776,7.34534114599228e-05)
> GCP[189]: Id=190, Info=
> (0,16668) ->
> (23.5784327345285,60.5857347657861,101.995043664239)
> GCP[190]: Id=191, Info=
> (1330,16668) ->
> (23.3419501463369,60.6119744037184,92.9953630361706)
> GCP[191]: Id=192, Info=
> (2660,16668) ->
> (23.1051220591634,60.6377918663013,81.9958192585036)
> GCP[192]: Id=193, Info=
> (3990,16668) ->
> (22.8677545319579,60.663207257434,75.9960280107334)
> GCP[193]: Id=194, Info=
> (5320,16668) ->
> (22.6301655843185,60.6881860056424,63.9965980853885)
> GCP[194]: Id=195, Info=
> (6650,16668) ->
> (22.3918751622281,60.7127774140065,63.9965005498379)
> GCP[195]: Id=196, Info=
> (7980,16668) ->
> (22.1536045415519,60.7369069050535,48.9972993964329)
> GCP[196]: Id=197, Info=
> (9310,16668) ->
> (21.9148572452888,60.7606248295136,37.9978934926912)
> GCP[197]: Id=198, Info=
> (10640,16668) ->
> (21.6758885074244,60.7839055031505,20.998886984773)
> GCP[198]: Id=199, Info=
> (11970,16668) ->
> (21.4363204973685,60.8067845762658,13.9992906386033)
> GCP[199]: Id=200, Info=
> (13300,16668) ->
> (21.196564510859,60.8292223305659,0.000160717405378819)
> GCP[200]: Id=201, Info=
> (14630,16668) ->
> (20.956151075518,60.8512613393296,0.000148872844874859)
> GCP[201]: Id=202, Info=
> (15960,16668) ->
> (20.7154116843961,60.87287006631,0.000137860886752605)
> GCP[202]: Id=203, Info=
> (17290,16668) ->
> (20.4743519660475,60.8940476328532,0.000127619132399559)
> GCP[203]: Id=204, Info=
> (18620,16668) ->
> (20.2329775958694,60.9147931183061,0.00011808704584837)
> GCP[204]: Id=205, Info=
> (19950,16668) ->
> (19.9912942942284,60.9351055557286,0.000109212473034859)
> GCP[205]: Id=206, Info=
> (21280,16668) ->
> (19.7493078901042,60.9549841148223,0.000100946053862572)
> GCP[206]: Id=207, Info=
> (22610,16668) ->
> (19.5070242540933,60.9744279245244,9.37329605221748e-05)
> GCP[207]: Id=208, Info=
> (23940,16668) ->
> (19.2644492924356,60.9934360545769,8.65152105689049e-05)
> GCP[208]: Id=209, Info=
> (25270,16668) ->
> (19.0215890177372,61.0120077312895,7.9798512160778e-05)
> GCP[209]: Id=210, Info=
> (26588,16668) ->
> (18.7806444177441,61.0299803790617,7.35931098461151e-05)
> Metadata:
> ACQUISITION_START_TIME=2022-05-29T04:58:22.192693
> ACQUISITION_STOP_TIME=2022-05-29T04:58:47.191324
> BEAM_MODE=IW
> BEAM_SWATH=IW
> FACILITY_IDENTIFIER=Copernicus Ground Segment
> LINE_SPACING=1.000000e+01
> MISSION_ID=S1A
> MODE=IW
> ORBIT_DIRECTION=DESCENDING
> ORBIT_NUMBER=43421
> PIXEL_SPACING=1.000000e+01
> PRODUCT_TYPE=GRD
> SATELLITE_IDENTIFIER=SENTINEL-1
> SENSOR_IDENTIFIER=SAR
> SWATH=IW
> Subdatasets:
> SUBDATASET_1_NAME=SENTINEL1_CALIB:SIGMA0:/share/S1A_IW_GRDH_1SDV_20220529T045822_20220529T045847_043421_052F5A_01B5.SAFE/manifest.safe:IW_VH:INTENSITY
> SUBDATASET_1_DESC=Single band with IW swath and VH polarization and
> SIGMA0 calibration
> SUBDATASET_2_NAME=SENTINEL1_CALIB:BETA0:/share/S1A_IW_GRDH_1SDV_20220529T045822_20220529T045847_043421_052F5A_01B5.SAFE/manifest.safe:IW_VH:INTENSITY
> SUBDATASET_2_DESC=Single band with IW swath and VH polarization and
> BETA0 calibration
> SUBDATASET_3_NAME=SENTINEL1_CALIB:GAMMA:/share/S1A_IW_GRDH_1SDV_20220529T045822_20220529T045847_043421_052F5A_01B5.SAFE/manifest.safe:IW_VH:INTENSITY
> SUBDATASET_3_DESC=Single band with IW swath and VH polarization and
> GAMMA calibration
> SUBDATASET_4_NAME=SENTINEL1_CALIB:UNCALIB:/share/S1A_IW_GRDH_1SDV_20220529T045822_20220529T045847_043421_052F5A_01B5.SAFE/manifest.safe:IW_VH:AMPLITUDE
> SUBDATASET_4_DESC=Single band with IW swath and VH polarization and
> UNCALIB calibration
> SUBDATASET_5_NAME=SENTINEL1_CALIB:SIGMA0:/share/S1A_IW_GRDH_1SDV_20220529T045822_20220529T045847_043421_052F5A_01B5.SAFE/manifest.safe:IW_VV:INTENSITY
> SUBDATASET_5_DESC=Single band with IW swath and VV polarization and
> SIGMA0 calibration
> SUBDATASET_6_NAME=SENTINEL1_CALIB:BETA0:/share/S1A_IW_GRDH_1SDV_20220529T045822_20220529T045847_043421_052F5A_01B5.SAFE/manifest.safe:IW_VV:INTENSITY
> SUBDATASET_6_DESC=Single band with IW swath and VV polarization and
> BETA0 calibration
> SUBDATASET_7_NAME=SENTINEL1_CALIB:GAMMA:/share/S1A_IW_GRDH_1SDV_20220529T045822_20220529T045847_043421_052F5A_01B5.SAFE/manifest.safe:IW_VV:INTENSITY
> SUBDATASET_7_DESC=Single band with IW swath and VV polarization and
> GAMMA calibration
> SUBDATASET_8_NAME=SENTINEL1_CALIB:UNCALIB:/share/S1A_IW_GRDH_1SDV_20220529T045822_20220529T045847_043421_052F5A_01B5.SAFE/manifest.safe:IW_VV:AMPLITUDE
> SUBDATASET_8_DESC=Single band with IW swath and VV polarization and
> UNCALIB calibration
> SUBDATASET_9_NAME=SENTINEL1_CALIB:SIGMA0:/share/S1A_IW_GRDH_1SDV_20220529T045822_20220529T045847_043421_052F5A_01B5.SAFE/manifest.safe:IW:INTENSITY
> SUBDATASET_9_DESC=IW swath with all polarizations (VH+VV) as bands
> and SIGMA0 calibration
> SUBDATASET_10_NAME=SENTINEL1_CALIB:BETA0:/share/S1A_IW_GRDH_1SDV_20220529T045822_20220529T045847_043421_052F5A_01B5.SAFE/manifest.safe:IW:INTENSITY
> SUBDATASET_10_DESC=IW swath with all polarizations (VH+VV) as bands
> and BETA0 calibration
> SUBDATASET_11_NAME=SENTINEL1_CALIB:GAMMA:/share/S1A_IW_GRDH_1SDV_20220529T045822_20220529T045847_043421_052F5A_01B5.SAFE/manifest.safe:IW:INTENSITY
> SUBDATASET_11_DESC=IW swath with all polarizations (VH+VV) as bands
> and GAMMA calibration
> SUBDATASET_12_NAME=SENTINEL1_CALIB:UNCALIB:/share/S1A_IW_GRDH_1SDV_20220529T045822_20220529T045847_043421_052F5A_01B5.SAFE/manifest.safe:IW:AMPLITUDE
> SUBDATASET_12_DESC=IW swath with all polarizations (VH+VV) as bands
> and UNCALIB calibration
> Corner Coordinates:
> Upper Left ( 0.0, 0.0)
> Lower Left ( 0.0,16669.0)
> Upper Right (26589.0, 0.0)
> Lower Right (26589.0,16669.0)
> Center (13294.5, 8334.5)
> Band 1 Block=26589x1 Type=UInt16, ColorInterp=Undefined
> Metadata:
> POLARIZATION=VH
> SWATH=IW
> Band 2 Block=26589x1 Type=UInt16, ColorInterp=Undefined
> Metadata:
> POLARIZATION=VV
> SWATH=IW
> gdalinfo failed - unable to open
> 'SENTINEL1_CALIB:SIGMA0:/share/S1A_IW_GRDH_1SDV_20220529T045822_20220529T045847_043421_052F5A_01B5.SAFE/manifest.safe:IW_VH:INTENSITY'.
> SENTINEL1_CALIB:UNCALIB:/share/S1A_IW_GRDH_1SDV_20220529T045822_20220529T045847_043421_052F5A_01B5.SAFE/manifest.safe:IW_VH:AMPLITUDEDriver:
> Files:
> GCP Projection =
> GEOGCRS["WGS 84",
> CS[ellipsoidal,2],
> ORDER[1],
> ORDER[2],
> ID["EPSG",4326]]
> (2660,0) ->
> (3990,0) ->
> (6650,0) ->
> (9310,0) ->
> (10640,0) ->
> (11970,0) ->
> (13300,0) ->
> (14630,0) ->
> (15960,0) ->
> (17290,0) ->
> (18620,0) ->
> (19950,0) ->
> (21280,0) ->
> (22610,0) ->
> (23940,0) ->
> (25270,0) ->
> (26588,0) ->
> (1330,2001) ->
> (2660,2001) ->
> (3990,2001) ->
> (5320,2001) ->
> (6650,2001) ->
> (7980,2001) ->
> (9310,2001) ->
> (10640,2001) ->
> (11970,2001) ->
> (13300,2001) ->
> (14630,2001) ->
> (15960,2001) ->
> (17290,2001) ->
> (18620,2001) ->
> (19950,2001) ->
> (21280,2001) ->
> (22610,2001) ->
> (23940,2001) ->
> (25270,2001) ->
> (26588,2001) ->
> (0,4002) ->
> (1330,4002) ->
> (2660,4002) ->
> (3990,4002) ->
> (5320,4002) ->
> (6650,4002) ->
> (7980,4002) ->
> (9310,4002) ->
> (10640,4002) ->
> (11970,4002) ->
> (13300,4002) ->
> (14630,4002) ->
> (15960,4002) ->
> (17290,4002) ->
> (18620,4002) ->
> (19950,4002) ->
> (21280,4002) ->
> (22610,4002) ->
> (23940,4002) ->
> (25270,4002) ->
> (26588,4002) ->
> (1330,6003) ->
> (2660,6003) ->
> (3990,6003) ->
> (5320,6003) ->
> (6650,6003) ->
> (7980,6003) ->
> (9310,6003) ->
> (10640,6003) ->
> (11970,6003) ->
> (13300,6003) ->
> (14630,6003) ->
> (15960,6003) ->
> (17290,6003) ->
> (18620,6003) ->
> (19950,6003) ->
> (21280,6003) ->
> (22610,6003) ->
> (23940,6003) ->
> (25270,6003) ->
> (26588,6003) ->
> (1330,8004) ->
> (2660,8004) ->
> (3990,8004) ->
> (5320,8004) ->
> (6650,8004) ->
> (7980,8004) ->
> (9310,8004) ->
> (10640,8004) ->
> (11970,8004) ->
> (13300,8004) ->
> (14630,8004) ->
> (15960,8004) ->
> (17290,8004) ->
> (18620,8004) ->
> (19950,8004) ->
> (21280,8004) ->
> (22610,8004) ->
> (23940,8004) ->
> (25270,8004) ->
> (26588,8004) ->
> (0,10005) ->
> (1330,10005) ->
> (2660,10005) ->
> (3990,10005) ->
> (5320,10005) ->
> (6650,10005) ->
> (7980,10005) ->
> (9310,10005) ->
> (10640,10005) ->
> (11970,10005) ->
> (13300,10005) ->
> (14630,10005) ->
> (15960,10005) ->
> (17290,10005) ->
> (18620,10005) ->
> (19950,10005) ->
> (21280,10005) ->
> (22610,10005) ->
> (23940,10005) ->
> (25270,10005) ->
> (26588,10005) ->
> (0,12006) ->
> (1330,12006) ->
> (2660,12006) ->
> (3990,12006) ->
> (5320,12006) ->
> (6650,12006) ->
> (7980,12006) ->
> (9310,12006) ->
> (10640,12006) ->
> (11970,12006) ->
> (13300,12006) ->
> (14630,12006) ->
> (15960,12006) ->
> (17290,12006) ->
> (18620,12006) ->
> (19950,12006) ->
> (21280,12006) ->
> (22610,12006) ->
> (23940,12006) ->
> (25270,12006) ->
> (26588,12006) ->
> (0,14007) ->
> (1330,14007) ->
> (2660,14007) ->
> (3990,14007) ->
> (5320,14007) ->
> (6650,14007) ->
> (7980,14007) ->
> (9310,14007) ->
> (10640,14007) ->
> (11970,14007) ->
> (13300,14007) ->
> (14630,14007) ->
> (15960,14007) ->
> (17290,14007) ->
> (18620,14007) ->
> (19950,14007) ->
> (21280,14007) ->
> (22610,14007) ->
> (23940,14007) ->
> (25270,14007) ->
> (26588,14007) ->
> (0,16008) ->
> (1330,16008) ->
> (2660,16008) ->
> (3990,16008) ->
> (5320,16008) ->
> (6650,16008) ->
> (7980,16008) ->
> (9310,16008) ->
> (10640,16008) ->
> (11970,16008) ->
> (13300,16008) ->
> (14630,16008) ->
> (15960,16008) ->
> (17290,16008) ->
> (18620,16008) ->
> (19950,16008) ->
> (21280,16008) ->
> (22610,16008) ->
> (23940,16008) ->
> (25270,16008) ->
> (26588,16008) ->
> (0,16668) ->
> (1330,16668) ->
> (2660,16668) ->
> (3990,16668) ->
> (5320,16668) ->
> (6650,16668) ->
> (7980,16668) ->
> (9310,16668) ->
> (10640,16668) ->
> (11970,16668) ->
> (13300,16668) ->
> (14630,16668) ->
> (15960,16668) ->
> (17290,16668) ->
> (18620,16668) ->
> (19950,16668) ->
> (21280,16668) ->
> (22610,16668) ->
> (23940,16668) ->
> (25270,16668) ->
> (26588,16668) ->
> Metadata:
> BEAM_MODE=IW
> BEAM_SWATH=IW
> MISSION_ID=S1A
> MODE=IW
> ORBIT_NUMBER=43421
> PRODUCT_TYPE=GRD
> SWATH=IW
> Corner Coordinates:
> Metadata:
> POLARIZATION=VH
> SWATH=IW
http://www.spatialys.com
