[gdal-dev] Specify Grid Rotation for gdal.Warp() with Geolocation Arrays
Michael Sumner
mdsumner at gmail.com
Fri Nov 4 16:57:51 PDT 2022
well, the map projection does this - there are many possibilities. Or, do
you have another geolocation array you want as the target?
If you have an example I'm happy to try a few things, but I'd assumed you
had a target map projection in mind. What kind of crs to choose depends on
your goal, or is purely to not have north up?
Perhaps there's something terminology wise I'm missing ...
Mike
On Sat, 5 Nov 2022, 10:50 Brendan Heberlein, <bheberlein at wisc.edu> wrote:
> Hi Mike,
> thanks for the response.
> Can you clarify how I would go about specifying the grid orientation for
> the output raster? None of -te, -ts or -t_srs address this.
> *From:* Michael Sumner <mdsumner at gmail.com>
> *Sent:* Friday, November 4, 2022 6:41 PM
> *To:* Brendan Heberlein <bheberlein at wisc.edu>
> *Cc:* gdal-dev <gdal-dev at lists.osgeo.org>
> *Subject:* Re: [gdal-dev] Specify Grid Rotation for gdal.Warp() with
> Geolocation Arrays
> that's exactly what the warper does with geolocation arrays, set the
> target extent, dimension, and crs with -te, -ts, -t_srs with gdalwarp.
> python will have those analogous controls for the warper.
> Cheers, Mike
> On Sat, 5 Nov 2022, 01:23 Brendan Heberlein via gdal-dev, <
> gdal-dev at lists.osgeo.org> wrote:
> Hello,
> I would like to be able to warp an image dataset using a geolocation
> array, while specifying the grid to which the output dataset is sampled.
> Specifically, I want to be able to warp the dataset to a grid which is not
> oriented North-up.
> Can GDAL support this currently? Or, what is the likelihood this could be
> supported in the future?
> I primarily rely on the Python bindings, so a solution within that
> framework would be ideal for me.
> Thanks!
> — Brendan
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221105/8d1dfa3a/attachment-0001.htm>
