[gdal-dev] A CSW query that seems to me works badly
    Even Rouault
    even.rouault at spatialys.com
    Fri Nov 18 04:01:26 PST 2022
This is mostly an implementation detail that should have no
consequences. If you really want to change that, I'd suggest you to
submit a pull request with the change directly.
Hint:  go to
https://github.com/OSGeo/gdal/edit/master/ogr/ogrsf_frmts/wfs/ogrwfsfilter.cpp
, do the change and use the UI to submit it as pull request
Le 18/11/2022 à 09:02, andy a écrit :
> Hi,
> I think this is a small bug, but not if it depends on OGR or the
> server I query.
> If I run
> ogrinfo --debug on -ro -al "CSW:http://geodati.gov.it/RNDT/csw" -where
> "subject LIKE 'salute'"
> I have the below XML query:
> <?xml version="1.0" encoding="UTF-8"?>
> <csw:GetRecords resultType="results" service="CSW" version="2.0.2"
> startPosition="1" maxRecords="500"
> xmlns:csw="http://www.opengis.net/cat/csw/2.0.2"
> xmlns:gml="http://www.opengis.net/gml"
> xmlns:dc="http://purl.org/dc/elements/1.1/"
> xmlns:dct="http://purl.org/dc/terms/"
> xmlns:ogc="http://www.opengis.net/ogc"
> xmlns:ows="http://www.opengis.net/ows"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:schemaLocation="http://www.opengis.net/cat/csw/2.0.2
> http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd">
>   <csw:Query typeNames="csw:Record">
> <csw:ElementSetName>full</csw:ElementSetName>
>     <csw:Constraint version="1.1.0">
>       <ogc:Filter>
>         <ogc:PropertyIsLike wildCard='*' singleChar='_' escapeChar='!'>
> <ogc:PropertyName>dc:subject</ogc:PropertyName>
>           <ogc:Literal>salute</ogc:Literal>
>         </ogc:PropertyIsLike>
>       </ogc:Filter>
>     </csw:Constraint>
>   </csw:Query>
> </csw:GetRecords>
> As you can see we have single quotes in
> For reasons of uniformity and consistency I think here too there
> should be double quotes.
> Am I wrong?
> If not, could I open an issue?
> Thank you
> ___________________
> Andrea Borruso
> website: https://medium.com/tantotanto
> 38° 7' 48" N, 13° 21' 9" E, EPSG:4326
> ___________________
> "cercare e saper riconoscere chi e cosa,
>  in mezzo all’inferno, non è inferno,
> e farlo durare, e dargli spazio"
> Italo Calvino
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221118/789f1e3c/attachment.htm>
