[gdal-dev] Latest GDAL version not transforming lat/lng into geom column
Rahkonen Jukka jukka.rahkonen at maanmittauslaitos.fi
Mon Nov 21 01:28:15 PST 2022
Please add a one line test file "my_file.csv" so we can try to reproduce. Confirm first that it fails with your GDAL version.
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Moises Calzado via gdal-dev
Lähetetty: maanantai 21. marraskuuta 2022 11.21
Vastaanottaja: gdal-dev at lists.osgeo.org
Aihe: [gdal-dev] Latest GDAL version not transforming lat/lng into geom column
Hello everyone,
We've just updated to the latest GDAL version (v3.6.0) and it seems that something is not working correctly when trying to obtain a geom column from a CSV containing latitudes and longitudes.
This is the command that is being used:
ogr2ogr -f CSV -skipfailures -makevalid /vsistdout/ CSV:my_file.csv -simplify 0.00001 -dim XY -t_srs EPSG:4326 -lco GEOMETRY=AS_WKT -lco GEOMETRY_NAME=geom -lco CREATE_CSVT=YES -s_srs EPSG:4326 -oo KEEP_GEOM_COLUMNS=NO -oo X_POSSIBLE_NAMES=point_longitude,longitude,longitud,lon,Lon,Longitude,longitudedecimal,decimallongitude,decimallong,lng,long,Lng -oo Y_POSSIBLE_NAMES=latitude,latitud,lati,lat,Latitude,decimallat,decimallatitude,latitudedecimal,point_latitude -oo GEOM_POSSIBLE_NAMES=geom,Geom,geometry,the_geom,wkt,wkb,wkt_geometry,wkb_geometry -oo EMPTY_STRING_AS_NULL=YES -oo QUOTED_FIELDS_AS_STRING=NO -lco PRECISION=NO -oo AUTODETECT_SIZE_LIMIT=500000
The file that is being processed contains a column called lat and another one called lon, and when I execute the same process on a docker container running the version 3.5.1 of GDAL it works like a charm. We've also tried to execute this process on the 3.5.3 version, and it also fails. Is that expected?
Looking forward to your response,
Regards!
Moises Calzado
Support Engineer
(US) +1 917 463 3232 | (ES) +34 911 165 823 | mcalzado at carto.com<mailto:mcalzado at carto.com>
[https://storage.googleapis.com/carto-it-files/signature/default-signature.png]<https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.carto.com%2F&data=05%7C01%7Cjukka.rahkonen%40maanmittauslaitos.fi%7Cd1e743f3f6e1426d2b6608dacba1bb9d%7Cc4f8a63255804a1c92371d5a571b71fa%7C0%7C0%7C638046192744569448%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=NTmsAq57hnuviEyreG4QGZ6m%2F0lKaUk3CeSBD7q47Uk%3D&reserved=0>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221121/168eca51/attachment.htm>
