[gdal-dev] Working with IFC files
Stefano Iacovella
stefano.iacovella at gmail.com
Wed Nov 23 00:57:53 PST 2022
Thank you Jean-Roc for your information.
I am afraid I will have to stick to proprietary ESRI procedures to ingest
IFC files.
All the best
Stefano
Il giorno ven 18 nov 2022 alle ore 18:14 Jean-Roc Morreale (ml) <
jrmorreale_ml at enoreth.net> ha scritto:
> In this study, after talking with Even, the full support of IFC was
> deemed to exceed the functionalities of GDAL but the transformation of
> a limited subset to the Simple Feature model could be supported (such
> as the outer hull of a building, the shape of the floor, etc.).
> We did not pursue this track as we wanted a full support in QGIS (which
> isn't straightforward either).
> Le mercredi 16 novembre 2022 à 11:22 +0100, Jean-Roc Morreale (ml) a
> écrit :
> > Hi, we sponsored a feasability study for ifc support in qgis/gdal in
> > 2021, it is in in french but I'll try to sum it up asap
> > Le mercredi 16 novembre 2022 à 10:00 +0100, Stefano Iacovella a
> > écrit :
> > > Hi all,
> > > I am working with BIM data to integrate them in a geodatabase.
> > > Data are delivered in IFC format (1)
> > > I am curious about the possibility to ingest them using OGR.
> > > As far as I know there's no driver available.
> > > Is there someone in the list who has had some experience in a
> > > similar
> > > scenario?
> > > Thank you
> > > Stefano
> > > 1) https://standards.buildingsmart.org/IFC/DEV/IFC4_2/FINAL/HTML/
> > > _______________________________________________
> > > gdal-dev mailing list
> > > gdal-dev at lists.osgeo.org
> > > https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221123/1c85c8cf/attachment.htm>
