[gdal-dev] Compilation error with JP2KAK driver
Johannes Paul
johannespaul92 at gmail.com
Thu Nov 24 05:37:07 PST 2022
Hello Even,
Thanks for your reply, i did notice that, however libkdu_a82R.so is not
generated at kakadu compilation.
I only get libkdu_v82R.so and libkdu.a
Rgds,
Johannes
Le jeu. 24 nov. 2022 à 14:14, Even Rouault <even.rouault at spatialys.com> a
écrit :
> The value of KDU_AUX_LIBRARY is wrong. See
> https://gdal.org/development/building_from_source.html#cmdoption-arg-KDU_AUX_LIBRARY
> It should be -DKDU_AUX_LIBRARY="${INSTALLDIR}"/lib/libkdu_a82R.so"
> Even
> Le 24/11/2022 à 10:35, Johannes Paul a écrit :
> > Hello,
> > I'm having trouble compiling GDAL 3.6.0 on Centos7 with JP2KAK driver
> > using Kakadu 8.2.
> > I'm following the below instructions to compile KDU
> > https://trac.osgeo.org/gdal/wiki/JP2KAK
> > And I'm using the following cmake options to compile GDAL
> > -DGDAL_USE_KDU=ON -DKDU_INCLUDE_DIR="${INSTALLDIR}"
> > -DKDU_LIBRARY="${INSTALLDIR}"/lib/libkdu_v82R.so
> -DKDU_AUX_LIBRARY="${INSTALLDIR}"/lib/libkdu.a -DGDAL_ENABLE_DRIVER_JP2KAK:BOOL=ON
> > Everything goes fine until Linking CXX shared library libgdal.so
> > where I get multiple errors type jp2kakdataset.cpp:(.text+0x396):
> > undefined reference to `kdu_supp...
> > I've noticed the issue has already been addressed, unfortunately it
> > does not solve my problem ...
> > https://github.com/OSGeo/gdal/issues/4306
> > Thanks for your help
> > Johannes
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221124/3e792bd1/attachment.htm>
