[gdal-dev] ECRG RasterIO problem
mchapman at hyperacktive.com
Tue Oct 4 08:53:57 PDT 2022
Even,
You are my new hero. That worked!
Question: Should I always use GDAL_FORCE_CACHING=YES or is it driver specific? I would like to just set it to YES once at startup and forget about it. What are the pros and cons of setting it to YES / NO?
Thanks for committing that change.
Best regards,
Martin
Sent: Monday, October 3, 2022 5:08 PM
To: mchapman at hyperacktive.com; gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] ECRG RasterIO problem
Martin,
I bet you have GDAL_FORCE_CACHING=YES set. At least that was the only way I could trigger the error.
I've queued in https://github.com/OSGeo/gdal/pull/6464 a fix for that.
The first commit is sufficient to fix the issue despite being a bit hacky, but you could cherry-pick it without changing GDAL ABI
The second commit is a cleaner fix.
Even
Le 03/10/2022 à 19:05, mchapman at hyperacktive.com <mailto:mchapman at hyperacktive.com> a écrit :
All,
I have an ECRG dataset that fails when reading pixels from the gdalrasterband object on one of the subdatasets. It appears that the underlying proxy dataset has a macro check called RB_PROXY_METHOD_WITH_RET_WITH_INIT_BLOCK that fails because the block sizes are different. This happens for all the ECRG subdatasets that I read from, in other words it’s not just specific to a single dataset. FYI, the same code works fine for RPFTOC datasets and all other GDAL formats. I am using GDAL version 3.4.2.
// code snippet from gdalproxydataset.cpp line 247
else if( nSrcBlockXSize != nBlockXSize || nSrcBlockYSize != nBlockYSize) \
CPLError(CE_Failure, CPLE_AppDefined, "Inconsistent block dimensions between proxy and source"); \
ret = CE_Failure; \
The variables nBlockXSize and nBlockYSize are (2304, 1) and nSrcBlockXSize and nSrcBlockYSize are {128, 128).
I think this is because the ECRG frame size is 2304 x 2304 but the block size of the frame file is 128 x 128.
Does anybody know what my problem might be or is this an error in the driver code?
Best regards,
Martin
gdal-dev mailing list
gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221004/38a0ffd6/attachment.htm>
