[gdal-dev] four threads are huh, five are buh? Regressions w/ GDAL 3.5.2/PROJ_9.1.0
Even Rouault
even.rouault at spatialys.com
Tue Oct 11 06:10:30 PDT 2022
Christian,
I suspect the issue is not that much jumping from 4 to 5 threads, but
some latent issue in your code or in GDAL/PROJ that becomes more
visible. First thing to check: are you sure you are not using a given
GDAL / OGR object simultaneously in more than one thread ?
If that's not the issue, if you want effective help, I'm afraid you'll
have to go through the effort of writing a minimal standalone reproducer
(code+data) that you can share with us.
Even
Le 11/10/2022 à 14:56, Christian Brock via gdal-dev a écrit :
> I have some special issue and would be glad for suggestions.
> We run complex regression tests using environmental files -- too complex for a bug report ;-(
> Moving from GDAL_2.4.2/PROJ_5.2.0 to GDAL 3.5.2/PROJ_9.1.0 we run into regressions.
> The most stunning observation is that the issue only occurs when USING MORE THAN FOUR THREADS!
> Can anyone think of something that is true with five or more threads but not below?
> Besides this I should mention, that we use Java bindings
> The issue is
> - file format independent,
> - were observed on ubuntu 20.04 and 22.04,
> - affects a sample with the following coordinate system:
> PROJCS["Transverse Mercator",GEOGCS["Potsdam_IST_V2_0",DATUM["Potsdam_IST_V2_0",SPHEROID["Bessel",6377397.155,299.152813106079],TOWGS84[583,68,399.5,0,0,1.36E-05,1.13E-05]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",9],PARAMETER["scale_factor",1],PARAMETER["false_easting",3500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Easting",EAST],AXIS["Northing",NORTH]]"
> - WGS84 and all UTM systems are good.
> I should also mention, that this issue affects only the second sample, when I run more than one sample with the PROJCS above.
> When I change the sample order, it is the second sample again!
> And as a final point, there are random memory corruptions every couple of hours.
> So again, please step forward when you know of anything inside GDAL, PROJ or Java bindings that cares about the number of threads.
> Many thanks
> --Chr.
> This email and the information contained herein is proprietary and confidential and subject to the Amdocs Email Terms of Service, which you may review at https://www.amdocs.com/about/email-terms-of-service <https://www.amdocs.com/about/email-terms-of-service>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
