[gdal-dev] ogr2ogr preserve fid behavior
Rahkonen Jukka
jukka.rahkonen at maanmittauslaitos.fi
Thu Oct 13 01:27:58 PDT 2022
I think that shapefile does not have a proper fid to preserve. I am remembering that I have used the -sql option sometimes for controlling the FID, something like -sql “SELECT geometry, id AS FID, attribute_1, attribute_2 … FROM …”
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Alexandre Gacon
Lähetetty: torstai 13. lokakuuta 2022 11.13
Vastaanottaja: gdal-dev <gdal-dev at lists.osgeo.org>
Aihe: [gdal-dev] ogr2ogr preserve fid behavior
Hello,
I am trying to upload some data from SHP to Postgres. I would like to use a given column of my SHP as primary key in replacement of the id generated by ogr2ogr but I don't manage to have the result I want.
I used the options -preserve_fid and --config PGSQL_OGR_FID id which gave the following output: I have a column "id" as primary key but it does not contain the value of my SHP but an auto increment value.
The SHP is not used directly but I do some computations and name changes using a sql statement with the sqlite dialect.
Any idea on how I could have directly my "id" column as primary key with the values of my input ?
Alexandre Gacon
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221013/97fd85d2/attachment-0001.htm>
