[gdal-dev] [Doc] gdal_calc.py extent option
Idan Miara idan at miara.com
Mon Oct 17 01:54:52 PDT 2022
Hi!
I needed the docs are correct but as this is the second time it confuses
people maybe the wording should be revised?
https://github.com/OSGeo/gdal/pull/5969
Any ideas?
On Mon, 17 Oct 2022, 11:49 Nicolas Godet, <nicolas.godet at outlook.fr> wrote:
> Indeed, this is right.
> My bad..
> *De :* Andrew C Aitchison <andrew at aitchison.me.uk>
> *Envoyé :* lundi 17 octobre 2022 10:25
> *À :* Nicolas Godet <nicolas.godet at outlook.fr>
> *Cc :* gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
> *Objet :* Re: [gdal-dev] [Doc] gdal_calc.py extent option
> On Mon, 17 Oct 2022, Nicolas Godet wrote:
> > Dear Devs,
> > In documentation<
> https://gdal.org/programs/gdal_calc.html#cmdoption-extent>, extent param
> description seems a bit odd to me.
> > union - the extent (bounds) of the output will be the minimal
> > rectangle that contains all the input extents.
> > intersect - the extent (bounds) of the output will be the maximal
> > rectangle that is contained in all the input extents.
> > Shouldn't it be the other way around?
> I think this *is* the right way round;
> "all" can be misunderstood but I can not think of a clearer phrasing,
> although "every one of" might help.
> > As I intend to add this option to QGIS gdal_calc window (very useful
> > option), I must be sure.
> Andrew C. Aitchison                      Kendal, UK
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221017/e7941b05/attachment-0001.htm>
