[gdal-dev] Transformations with same horizontal datum but different geoid outputs the same Z value
Diogo
diogo at photopills.com
Mon Oct 17 01:59:01 PDT 2022
Hi Andrew. Thanks for taking the time to read my email and reply it.
I'm aware of Copernicus land and other datasets like SMRT3 and ASTER
however I need the best possible elevation resolution available. To do so,
I'm getting the elevation dataset directly from countries geographic
institutes and converting them into the coordinate system 4326+3855. But as
described in my previous email, I'm having some trouble with some geoids.
Do you have an idea why I'm having these transformation issues? To be
honest, I'm a bit lost because I can't understand it.
Thanks again for your help,
Diogo
On Fri, 14 Oct 2022 at 15:57, Andrew C Aitchison <andrew at aitchison.me.uk>
wrote:
> On Fri, 14 Oct 2022, Diogo wrote:
> > Hello everyone!
> > I'm merging multiple elevation datasets from different countries and I
> > would like to re-project all into the same coordinates system, 4326+3855
> > using gdalwarp. I'm using `gdaltransform` to confirm that there is in
> fact
> > a conversion from the original projection to the aspected one. However,
> for
> > some datasets, there is only conversion in the XY axis, while the Z
> output
> > is the same as the input.
> Is there a good reason to start with these particular datasets ?
> There are international bodies who have produced elevation datasets
> covering the whole of
> Europe, eg
> https://land.copernicus.eu/user-corner/how-to-access-our-data
> https://www.eea.europa.eu/data-and-maps/data#c0=5&c11=&c5=all&b_start=0&c12=elevation
> https://www.eea.europa.eu/data-and-maps/data/copernicus-land-monitoring-service-eu-dem
> which would save you trying to stitch together data in different CRSes.
> > Below there are some examples (the geoid code is extracted from the
> dataset
> > documentation)
> > Genoa 1942 height (Italy)
> > $ echo "14.995 37.755 3357" | PROJ_NETWORK=ON gdaltransform --debug on
> > -s_srs "EPSG:4326+3855" -t_srs "EPSG:32632+5214">> 1028333.73796622
> > 4195591.29690422 3357
> > N2000 (Finland)
> > $ echo "25.15296 62.50195 269" | PROJ_NETWORK=ON gdaltransform --debug
> > on -s_srs "EPSG:4326+3855" -t_srs "EPSG:3067+3900">> 404861.868388335
> > 6931460.32557422 269
> > EVRF2007 (Estonia)
> > $ echo "27.059167 57.714444 318" | PROJ_NETWORK=ON gdaltransform
> > --debug on -s_srs "EPSG:4326+3855" -t_srs "EPSG:3301+5621">>
> > 682284.606829111 6401087.4159131 318
> > I don't have much experience with the projections and I'm a bit lost
> > to understand the possible issues, or interpreted the Z output. What
> > can be the possible issues?
> > Any help would be appreciated.
> > Best regards,
> > Diogo
> Andrew C. Aitchison Kendal, UK
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221017/778b5766/attachment.htm>
