[gdal-dev] Problem with coordinate transformation
Laurențiu Nicola
lnicola at dend.ro
Tue Oct 18 04:01:13 PDT 2022
Hi Philippe,
The new behaviour is correct. See https://gdal.org/development/rfc/rfc73_proj6_wkt2_srsbarn.html#axis-order-issues for the axis order issue, a change made in GDAL 3.0. You can find a solution in https://github.com/OSGeo/gdal/blob/v3.5.0/MIGRATION_GUIDE.TXT#L67 (calling SetAxisMappingStrategy(OAMS_TRADITIONAL_GIS_ORDER) on every OGRSpatialReference you use.
Laurentiu
On Tue, Oct 18, 2022, at 13:43, Philippe Lelong wrote:
> Hi,
> I have an app build against GDAL 3.4.1 and PROJ6, and the same app build against GDAL 2.1.3 and PROJ4. They are not giving the same result when using OGRCoordinateTransformation.
> If I do
> const char *their = "GEOGCS[\"WGS 84\",DATUM[\"WGS_1984\",SPHEROID[\"WGS 84\",6378137,298.257223563,AUTHORITY[\"EPSG\",\"7030\"]],AUTHORITY[\"EPSG\",\"6326\"]],PRIMEM[\"Greenwich\",0],UNIT[\"degree\",0.0174532925199433],AUTHORITY[\"EPSG\",\"4326\"]]";
> const char *our = "+proj=longlat +datum=WGS84 +ellps=WGS84 +no_defs +over";
> double miX = -17.4042;
> double miY = 35.3333;
> OGRSpatialReference theirReference;
> theirReference.importFromWkt((char**)&their);
> OGRSpatialReference ourReference;
> ourReference.importFromProj4(our);
> OGRCoordinateTransformation *trans = OGRCreateCoordinateTransformation(&theirReference, &ourReference);
> trans->Transform(1, &miX, &miY);
> in the version build against GDAL 3.4.1/PROJ6 this code results in swapping miX and miY (i.e. miX = 35.3333 and miY = -17.4042)
> The version build against GDAL 2.1.3/PROJ4 leaves miX and miY unchanged, which I believe is correct.
> Any explanation for this behavior and which one is correct? Would I get the same result using PROJ8 ?
> Thanks in advance
> Philippe Lelong
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221018/44eb31fd/attachment-0001.htm>
