[gdal-dev] ogr SSL errors on ubuntu
Even Rouault
even.rouault at spatialys.com
Thu Oct 20 12:58:11 PDT 2022
Jorge,
Fix/workaround and links to related issues in
https://github.com/OSGeo/gdal/pull/6561
The curl binary manages to ignore that, but I couldn't easily spot
how/where in its source code.
The difference in errors are due to your curl versions using different
backends: gnutls vs openssl.
Even
Le 20/10/2022 à 20:35, Jorge Gustavo Rocha a écrit :
> Hi,
> Lately, I have problems opening some datasets using ogr2ogr or ogrinfo
> due to SSL errors.
> I think others tools like curl had the same kind of problems, but now
> they seem to work well.
> Problems with ogr
> Example (GDAL 3.6.0dev-f033e1fa1e, released 2022/08/04):
> ogrinfo
> 'https://wssig3.azores.gov.pt/geoserver/ows?service=WFS&version=2.0.0&request=GetFeature&typename=ge:GE.Borehole&outputFormat=application/json&EXCEPTIONS=application/json&srsname=EPSG:5013'
> ERROR 1: OpenSSL SSL_read: error:0A000126:SSL routines::unexpected eof
> while reading, errno 0
> Example (GDAL 3.4.3, released 2022/04/22):
> ogrinfo
> ERROR 1: GnuTLS recv error (-110): The TLS connection was non-properly
> terminated.
> maybe related: https://github.com/openssl/openssl/issues/18574
> Has someone a nice workaround? Do we need to change ogr code to handle
> this?
> Regards,
> Jorge
http://www.spatialys.com
