[gdal-dev] Documentation of .gfs file format
Even Rouault even.rouault at spatialys.com
Thu Oct 27 05:14:01 PDT 2022
Johannes,
yes sure I can help
Even
Le 26/10/2022 à 16:39, Johannes Echterhoff a écrit :
> Even,
> Thanks for the source code reference. That was quite useful to
> identify even more XML elements that can occur in a gfs file.
> I’ll see what I can do about an xsd for gfs. Would you be willing to
> help me in this regard? That would mainly be clarification of schema
> specifics (like element types), as well as element semantics, where
> necessary.
> Best regards,
> Johannes
> *Von:* Even Rouault <even.rouault at spatialys.com>
> *Gesendet:* Dienstag, 25. Oktober 2022 20:08
> *An:* Johannes Echterhoff <echterhoff at interactive-instruments.de>;
> gdal-dev at lists.osgeo.org
> *Betreff:* Re: [gdal-dev] Documentation of .gfs file format
> Johannes,
> You have a number of .gfs templates file in
> https://github.com/OSGeo/gdal/tree/master/data
> <https://github.com/OSGeo/gdal/tree/master/data>
> Otherwise just read the code of GMLFeatureClass::InitializeFromXML()
> if you want to have the full view of what the GFS reader understand:
> https://github.com/OSGeo/gdal/blob/master/ogr/ogrsf_frmts/gml/gmlfeatureclass.cpp#L456
> <https://github.com/OSGeo/gdal/blob/master/ogr/ogrsf_frmts/gml/gmlfeatureclass.cpp#L456>which
> is the ultimate authoritative source. That said a .xsd file for .gfs
> could be useful, if that's something you'd be willing to contribute.
> Even
> Le 25/10/2022 à 15:16, Johannes Echterhoff a écrit :
>     Hello,
>     The documentation of the GML driver on
>     https://gdal.org/drivers/vector/gml.html
>     <https://gdal.org/drivers/vector/gml.html>has two sections that
>     describe the .gfs file format to some extent (section “Syntax of
>     .gfs file by example” and section “Advanced .gfs syntax”). When
>     looking for more information about the .gfs format, I came across
>     https://github.com/OSGeo/gdal/issues/1138
>     <https://github.com/OSGeo/gdal/issues/1138>, where <precision> was
>     mentioned as an additional element that can be used in .gfs files.
>     Is the .gfs. file format documented somewhere in full detail? I
>     would like to write .gfs template files, and in order to do so,
>     knowing all available elements, options, as well as syntax
>     requirements would be great to know. So far, I only came across a
>     number of examples – which certainly help – but I would like to
>     consult an authoritative source, if there is one.
>     Best regards,
>     Johannes
>     _______________________________________________
>     gdal-dev mailing list
>     gdal-dev at lists.osgeo.org  <mailto:gdal-dev at lists.osgeo.org>
>     https://lists.osgeo.org/mailman/listinfo/gdal-dev  <https://lists.osgeo.org/mailman/listinfo/gdal-dev>
> http://www.spatialys.com  <http://www.spatialys.com>
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221027/0c6e8ad6/attachment.htm>
