[gdal-dev] Rotated lat lon projection
Michael Sumner
mdsumner at gmail.com
Fri Sep 2 23:58:51 PDT 2022
First step is try shoving it through the warper:
gdalwarp in.nc out.tif
set lonlat extent with -te and resolution with -ts or -tr
GDAL knows about projections and internal coordinate arrays and often this
is enough, the smart things come down to what output grid you define and
what resampling algorithm is used and whether it's appropriate (beware of
vector quantities for example).
Use a VRT intermediate to first select out one band to test with
(gdal_translate in.nc in1.vrt -b 1). If you have a test file I'm happy to
explore.
Even if the auto stuff doesn't work you can engineer a lot with just
command line args and VRT even for complex grids.
Cheers, Mike
On Thu, 1 Sept 2022, 23:57 De Juan De España, Javier, <
jajuan_ext at acciona.com> wrote:
> Hi!
> We are developping a meteorology project in the Canadian domain where we
> use gdal to manage grib files.
> These *files are “rotated lat-lon” and we would like to switch to
> “regular lat-lon”* easily. I’m concerned that lastest versions of gdal
> can do this, but i would really appreciate some indications or information
> about how to do this.
> Thank very much!
> Javier de Juan
> [image: logo-bau]
> *Javier de Juan de España*
> Project Manager
> Smart Society Skill Center
> Digital Hub
> Avda Europa, 18
> 28108 Alcobendas (Madrid) – Spain
> +34 687 53 86 53
> [image: flecha]
> WWW.ACCIONA.COM <https://www.acciona.com/es/>
> [image: twitter] <https://twitter.com/ACCIONA>
> [image: facebook] <https://www.facebook.com/acciona>
> [image: link] <https://www.linkedin.com/company/acciona>
> [image: you]
> <https://www.youtube.com/user/interacciona1?sub_confirmation=1>
> [image: insta] <https://www.instagram.com/acciona/>
> Este mensaje se dirige exclusivamente a su destinatario, y puede contener
> información confidencial sometida a secreto profesional, o cuya divulgación
> esté legalmente prohibida. Cualquier opinión en él contenida es exclusiva
> de su autor y no representa necesariamente la opinión de la empresa. Si ha
> recibido este mensaje por error, le rogamos nos lo comunique de forma
> inmediata por esta misma vía y proceda a su eliminación, así como a la de
> cualquier documento adjunto al mismo. El correo electrónico vía Internet no
> es seguro y no se puede garantizar que no haya errores ya que puede ser
> interceptado, modificado, perdido o destruido, o contener virus. Cualquier
> persona que se ponga en contacto con nosotros por correo electrónico se
> considerará que asume estos riesgos.
> This e-mail is addressed exclusively to the recipient and may contain
> privileged information under a professional confidential agreement or it
> may be against the law to disclose its contents. Any opinion contained in
> it belongs exclusively to his/her author and does not necessarily reflect
> the company’s view. If you receive this e-mail in error, please let us know
> immediately (by return e-mail) and proceed to its destruction, as well as
> any document attached to it. The sending of e-mails through the Internet is
> not safe and, therefore, error-free communications cannot be guaranteed, as
> they can be intercepted, changed, misled or destroyed or they might contain
> a virus. Any user contacting us through e-mails shall be understood to be
> assuming these risks.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220903/8d6bf2fe/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220903/8d6bf2fe/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220903/8d6bf2fe/attachment-0009.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220903/8d6bf2fe/attachment-0010.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220903/8d6bf2fe/attachment-0011.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220903/8d6bf2fe/attachment-0012.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220903/8d6bf2fe/attachment-0013.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220903/8d6bf2fe/attachment-0014.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220903/8d6bf2fe/attachment-0015.png>
