[gdal-dev] Zarr syntax question
    Even Rouault
    even.rouault at spatialys.com
    Thu Sep  8 02:39:32 PDT 2022
Michael,
This is both a usage issue, and the driver not erroring out on that
invalid use whereas it should.
You should prefix the URL with /vsicurl/ , and if you use Bash as a
shell, to make sure the double quotes are preserved up to GDAL, you need
to surround the whole string with single quote characters.
So:
gdalmdiminfo
'ZARR:"/vsicurl/https://ncsa.osn.xsede.org/Pangeo/pangeo-forge/gpcp-feedstock/gpcp.zarr
<https://ncsa.osn.xsede.org/Pangeo/pangeo-forge/gpcp-feedstock/gpcp.zarr>"'
and similarly for gdalinfo:
gdalinfo
'ZARR:"/vsicurl/https://ncsa.osn.xsede.org/Pangeo/pangeo-forge/gpcp-feedstock/gpcp.zarr"'
gdalinfo
'ZARR:"/vsicurl/https://ncsa.osn.xsede.org/Pangeo/pangeo-forge/gpcp-feedstock/gpcp.zarr":/precip:0'
(0 here for the 2D slice at time index = 0)
In https://github.com/OSGeo/gdal/pull/6330, I've improved doc and error
messages.
Even
Le 08/09/2022 à 05:53, Michael Sumner a écrit :
> Hello, I'm trying to connect to this zarr:
> I can get this sort of hull description with mdim, but only "cannot
> find group" with gdalinfo.
> gdalmdiminfo
> ZARR:"https://ncsa.osn.xsede.org/Pangeo/pangeo-forge/gpcp-feedstock/gpcp.zarr"
>   "type": "group",
>   "driver": "Zarr",
>   "name": "/"
> gdalinfo
> ERROR 1: Cannot find group ncsa.osn.xsede.org <http://ncsa.osn.xsede.org>
> That group error makes me think there's a kind of nested dataset issue
> to navigate?  But I can't see how zarr or gdal would expose those?
>  There is a variable called 'precip'.
> I'm comparing to the python in this notebook, which works fine on the
> same system. I'm using GDAL built from source.
> https://notebooksharing.space/view/c6c1f3a7d0c260724115eaa2bf78f3738b275f7f633c1558639e7bbd75b31456#displayOptions=\
> Cheers, Mike
> Michael Sumner
> Software and Database Engineer
> Australian Antarctic Division
> Hobart, Australia
> e-mail: mdsumner at gmail.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220908/62b30bd0/attachment.htm>
