[gdal-dev] JPEG2000 via range request
Martin e11904212 at student.tuwien.ac.at
Mon Sep 12 13:07:22 PDT 2022
Thank you all for your answers. As andy already pointed out, this
behavior is due to the fact that
openjpeg is not utilizing markers yet when reading JPEG2000 files.
This issue seems to confirm that:
https://github.com/uclouvain/openjpeg/issues/944
So I tried the JP2ECW-ERDAS driver again with a current ECW version 5.5
(3.x does not seem to utilize TLMs either), which led to the desired result.
This way, the number of requests can be significantly reduced (~6 for
one tile).
Still a lot but sufficient for my use case.
I actually wanted to give kakadu a try too but unfortunately the source
code is needed to build it with gdal (which is not included in the demo).
- Martin
On 26.08.22 18:44, Norman Barker wrote:
> I wrote the original jpipkak driver years ago and it a driver I would
> suggest for deprecation but I am no longer involved in j2k development
> to know how much it is being used.
> You will need a jpip server to use the jpip client. Wavelets are
> different to cogs and you will get the benefits of progressive display.
> Norman
> On Fri, Aug 26, 2022, 5:12 PM Kurt Schwehr <schwehr at gmail.com> wrote:
>     It costs, but you could try this:
>     https://gdal.org/drivers/raster/jpipkak.html
>     I have kakadu, but I have never tried the jpip functionality so I
>     can't say how well it works.
>     On Fri, Aug 26, 2022, 5:03 AM Martin
>     <e11904212 at student.tuwien.ac.at> wrote:
>         Hi,
>         I want to process JP2 data via vsicurl. Which works so far.
>         Unfortunately hundreds of requests are sent, even if only the
>         data of one tile is required.
>         I understand that due to the structure of a JP2 file multiple
>         requests are necessary. But it looks like GDAL is searching
>         every single tile (resulting in ~120 requests).
>         Is there a way to reduce the number of requests?
>         I have already tried the JP2ECW-ERDAS driver, same result.
>         Do I have to configure GDAL in a certain way?
>         cmd for request:
>             #!/bin/bash
>             export GDAL_DISABLE_READDIR_ON_OPEN="YES"
>             export CPL_VSIL_CURL_ALLOWED_EXTENSIONS="jp2"
>             export CPL_CURL_VERBOSE="YES"
>             export GDAL_HTTP_MERGE_CONSECUTIVE_RANGES="YES"
>             gdal_translate --debug ON -srcwin 0 0 256 256
>         /vsicurl/http://localhost:8083/T33UWP_20220515T100031_TCI_10m_J2Lmin.jp2
>         ./out_subWin.tif
>         What options do I need to specify when creating the JP2 file
>         to support GDAL?
>         Currently I use the following options:
>         #!/bin/bash
>             gdal_translate \
>                 -of JP2OpenJPEG \
>                 -co QUALITY=100 \
>                 -co TLM=YES \
>                 -co PLT=YES \
>                 -co PROGRESSION=LRCP \
>                 -co WRITE_METADATA=YES \
>         ../test_data/T33UWP_20220515T100031_TCI_10m.tif \
>         ./T33UWP_20220515T100031_TCI_10m_J2Lmin.jp2
>         Some logs:
>         [gdal degug output](https://pastebin.com/vTf7tjLJ)
>         [nginx logs](https://pastebin.com/8bWW15Tp)
>         [gdalinfo](https://pastebin.com/HWSmypEQ)
>         [opj_dump](https://pastebin.com/rdYbHEnY)
>         [kdu_jp2info](https://pastebin.com/atVUfeVx)
>         _______________________________________________
>         gdal-dev mailing list
>         gdal-dev at lists.osgeo.org
>         https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220912/dc0f91a0/attachment.htm>
