[gdal-dev] odbc issue
Kurt Schwehr schwehr at gmail.com
Sat Sep 17 09:53:12 PDT 2022
Is the original data in FileMaker?  If so, is there something about
FileMaker that you specifically need?  Like is a FileMaker archaeology app
that you need?  And are there more updates to the data coming?
I ask because, if the data is static and there isn't anything special in
the land of FileMaker that you can't get elsewhere, then maybe you can
convert one time to something like geopackage and be done with FileMaker.
Then you can use any tool that reads that format including QGIS.  That
would make the problem much simpler.
On Fri, Sep 16, 2022, 4:07 AM Marghe via gdal-dev <gdal-dev at lists.osgeo.org>
wrote:
> Good morning,
> I write because I’ve a big issue. I’m an italian archaeologist and I’m
> doing a PhD in an archaeological site in Spain. My project was based on
> doing a gis on this site, but after an year working on it, my Professor
> told me I need to create an automatic connection between Filemaker and
> QGIS, otherwise I won’t be allow to continue my Phd, that for me it’s kind
> of like life and death.
> After some months of attempts I was able to connect the softwares through
> ODBC (but there are some bugs and it works only using some specific
> versions), but currently only filemaker can dialogue with QGIS but not vice
> versa. I think that the issue is that ODBC driver that filemaker use for
> connecting to QGIS is “read only”. I did some attempts also between
> filemaker and LibreOffice and I’ve the same issue, so I doubt could be that
> filemaker doesn’t give the permission for driver “writ”.
> Anyway I read here (
> https://gdal.org/drivers/vector/odbc.html?fbclid=IwAR2mUiMTb9hsGLpDdSaSY_qnpny8DUTDKc49WVkPw4yvizBBnPB9JoOByX8#creation-issues)
> that could be also a QGIS issue, so I want to know what do you think about
> that and if this problem could be solved implementing that. My PhD is
> without scholarship (so I’m not paid for this), but I’m so desperate that
> I’m willing to pay for resolve this problem and, in this cane, I need to
> know how much would be.
> Thank you so much.
> Margherita Zannini
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220917/7eb26c3c/attachment.htm>
