[gdal-dev] (no subject)
Even Rouault even.rouault at spatialys.com
Tue Sep 20 13:59:45 PDT 2022
addressed per https://github.com/OSGeo/gdal/pull/6407
Even
Le 19/09/2022 à 13:07, Moises Calzado via gdal-dev a écrit :
> Hello everyone,
> We're performing some tests with ogrinfo trying to read GPKG files,
> and we're facing some issues executing the command with remote GPKG
> files in WAL mode. As can be checked in the following command output,
> ogr fails while reading the file content:
>     ERROR: Error: Command failed: ogrinfo /vsicurl/MY_FILE_URL has
>     GPKG application_id, but non conformant file extension ERROR 1:
>     unable to open database file: this file is a WAL-enabled database.
>     It cannot be opened because it is presumably read-only or in a
>     read-only directory. ERROR 1: Only read-only mode is supported for
>     /vsicurl
> What is strange here is that the same file works correctly if we
> execute the command using the downloaded file.
> Is there any way we can execute the command using a remote file?
> Thanks so much in advance,
> Kind regards!
> *Moises Calzado*
> Support Engineer
> (US) +1 917 463 3232 | (ES) +34 911 165 823 | mcalzado at carto.com
> <https://spatial-data-science-conference.com/2022/newyork/>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20220920/9abfe9ab/attachment.htm>
