[gdal-dev] recent change?, issue with OGRGeometryFactory in R
Michael Sumner
mdsumner at gmail.com
Sat Apr 1 00:57:50 PDT 2023
Actually... this seems to be a problem on just one machine, I would have
thought they are the same but fwiw this seems not to be a GDAL or R package
problem.
I'll check again carefully so probably ignore this, thanks!
Cheers, Mike
On Sat, 1 Apr 2023, 16:24 Michael Sumner, <mdsumner at gmail.com> wrote:
> Hi,
> I'm here to ask for help finding where this issue is. If I use an earlier
> build it still works (these are R packages sf and terra that are well
> tested against previous releases).
> Has something changed with the headers structure for OGRGeometryFactory
> perhaps? (I'm out of my depth for how to track this down). If it's an
> issue on the R side I'll fix it there, but mostly I'm here to ask what has
> changed on the GDAL side to result in this symbol problem (or whatever it
> is I'm doing wrong).
> using latest build 24afc75d3c3f2c85621e8b8d83f54a73b1d3ad33
> I see
> > library(sf)
> Error: package or namespace load failed for ‘sf’ in dyn.load(file, DLLpath
> = DLLpath, ...):
> unable to load shared object
> '/usr/local/lib/R/site-library/sf/libs/sf.so':
> /usr/local/lib/R/site-library/sf/libs/sf.so: undefined symbol:
> _ZN18OGRGeometryFactory13createFromWktEPKcP19OGRSpatialReferencePP11OGRGeometry
> > library(terra)
> Error: package or namespace load failed for ‘terra’ in dyn.load(file,
> DLLpath = DLLpath, ...):
> '/usr/local/lib/R/site-library/terra/libs/terra.so':
> /usr/local/lib/R/site-library/terra/libs/terra.so: undefined symbol:
> Using a prior build eca6f7bf17fe500ef4c0ba9793e93ea305bab1fc it works.
> The offending code in terra is this (I think)
> https://github.com/rspatial/terra/blob/ddcf84ce901a269ac13118d650efac16f89a8602/src/read_ogr.cpp#L694
> In sf it is
> https://github.com/r-spatial/sf/blob/main/src/gdal_read.cpp#L582
> Thank you.
> Cheers, Mike
> Michael Sumner
> Software and Database Engineer
> Australian Antarctic Division
> Hobart, Australia
> e-mail: mdsumner at gmail.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230401/7ef7bbfe/attachment.htm>
