[gdal-dev] KML polygons with a label
Even Rouault
even.rouault at spatialys.com
Fri Apr 21 16:30:58 PDT 2023
> How do I get the LabelStyle correct?
What do you mean by "correct" ? Are you wishing to see the font, size
and text attributes translated in LabelStyle ? As far as I can see in
the KML spec, there is no direct equivalence for them.
There is a <scale> element that could perhaps emulate some sort of
scale, but this is an amplification factor, with 1 meaning nominal size.
So how a font size of 12 in Arial or Helvetica translates as scale...
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230422/a9a8bc45/attachment.htm>
