[gdal-dev] Failure to read some geojson files
Joaquim Manuel Freire Luís jluis at ualg.pt
Fri Apr 28 15:09:27 PDT 2023
Thanks Andrea,
I thought that could be the case and downloaded the file with a right-click-save-as and what I got seemed to be a valid json file and clearly not an html file. And that one doesn't work either. It does when I select to download as "raw".
Joaquim
-----Original Message-----
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Andrea Giudiceandrea via gdal-dev
Sent: Friday, April 28, 2023 8:23 PM
To: gdal-dev at lists.osgeo.org
Cc: Andrea Giudiceandrea <andreaerdna at libero.it>
Subject: Re: [gdal-dev] Failure to read some geojson files
Il 28/04/2023 19:08, Joaquim Manuel Freire Luís via gdal-dev ha scritto:
> This is with OSGeo4W GDAL but I get the same with my own build. But I
> can read some other geojson files. Why?
> ogrinfo
> https://github.com/OSGeo/PROJ/blob/9.1/docs/plot/data/coastline.geojso
> n
> <https://github.com/OSGeo/PROJ/blob/9.1/docs/plot/data/coastline.geojs
> on>
> ERROR 4: Failed to read TopoJSON data
Hi Joaquim,
the URL
https://github.com/OSGeo/PROJ/blob/9.1/docs/plot/data/coastline.geojson
does not point to the actual coastline.geojson file. It points to a GitHub HTML page.
You need to use the URL
https://github.com/OSGeo/PROJ/raw/9.1/docs/plot/data/coastline.geojson
instead.
Best regards.
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
