[gdal-dev] Ogr2ogr CSV driver not handling correctly line breaks inside columns
Even Rouault
even.rouault at spatialys.com
Sat Apr 29 06:44:02 PDT 2023
Moises,
as far as I can see with your example, the CSV driver behaves "properly"
in reading and writing of field values with line breaks.
It follows the "Fields with embedded line breaks must be quoted" rule of
https://en.wikipedia.org/wiki/Comma-separated_values
$ ogr2ogr out.csv /vsizip/dataframe.zip
$ cat out.csv
id,descriptio
"1",This is my third row
"2","this is
my string
"3",This is my third row
$ ogrinfo out.csv -al
INFO: Open of `out.csv'
using driver `CSV' successful.
Layer name: out
Geometry: None
Feature Count: 3
Layer SRS WKT:
(unknown)
descriptio: String (0.0)
OGRFeature(out):1
id (String) = 1
descriptio (String) = This is my third row
OGRFeature(out):2
id (String) = 2
descriptio (String) = this is
my string
OGRFeature(out):3
id (String) = 3
But in your example using /vsistdout/ and -lco CREATE_CSVT=YES is going
to result in an invalid CSV file which will mix both the .csvt and .csv
content
Even
Le 24/04/2023 à 13:34, Moises Calzado via gdal-dev a écrit :
> Hello!
> We're trying to convert a Shapefile into a CSV using ogr2ogr and we're
> having some issues while dealing with some columns that contain line
> breaks inside their values. If we have a line with the following
> string, ogr2ogr detects that the line break is a new line and it
> returns two lines.
> "this is my \n value"
> That's the command that we're executing:
> ogr2ogr -f CSV -skipfailures -makevalid /vsistdout/
> /vsizip/shapefile.zip -simplify 0.00001 -dim XY -t_srs EPSG:4326
> -lco GEOMETRY=AS_WKT -lco GEOMETRY_NAME=geom -lco CREATE_CSVT=YES
> > result.csv
> Is this an expected behaviour, or is there any way to avoid this?
> Sharing an example Shapefile so that you can try to reproduce that
> behaviour:
> https://drive.google.com/file/d/1gFqfTP02KTFoavJyyO-Ix05YwZB2tS24/view?usp=sharing
> Thanks so much in advance,
> Regards.
> *Moises Calzado*
> Support Engineer
> +34671264286 | mcalzado at carto.com | CARTO <https://www.carto.com/>
> <https://spatial-data-science-conference.com/2023/london/>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230429/9059e2c7/attachment.htm>
