[gdal-dev] MSSQLSpatial driver cmake build issues
Tamas Szekeres szekerest at gmail.com
Mon Feb 6 11:44:03 PST 2023
Hi GDAL Devs,
The GISInternals build SDK has been changed to use GDAL 3.6.x and therefore
it has completely switched to the cmake build. We noticed that this change
caused to break the appveyor builds for MapServer (with the error: Unable
to find driver `MSSQLSpatial' ).
Formerly the MSQLSpatial driver has been built into GDAL by default using
the legacy ODBC driver, but we could also compile plugin builds
against the *SQL
Server Native Client* and the new *SQL Server ODBC 17* driver, too. If
either of the plugins was installed with GDAL, the plugin driver (with the
same name) superseded the functionality of the built in driver.
With the cmake build - however - if we compile a plugin build (and only one
driver is supported) the built in driver is not compiled anymore.
The problem with the current solution is that neither the native client nor
the ODBC 17 drivers are installed on Windows by default and these drivers
require additional installations. When we install these plugins with GDAL,
it may cause a failure when the driver is loaded that the the related ODBC
driver dll-s couldn't be found on the system.
Would that be possible somehow to restore the original behavior for example
by modifying the cmake build setup for MSSQLSpatial, so that we could
create a built-in driver as well as one or more plugin drivers (against
different ODBC drivers) within the same cmake configuration? I guess it
would somewhat require to add multiple *add_library* entries in the cmake
setup, but I'm not sure how that fits into the current *add_gdal_driver*
ecosystem.
Thanks,
Tamas
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230206/e130899b/attachment.htm>
