[gdal-dev] Set axis order with ogr2ogr
Even Rouault
even.rouault at spatialys.com
Wed Feb 8 02:58:24 PST 2023
Set PROJ_LIB as an environment variable (with set
PROJ_LIB="D:\MDT\V9\bin\gdal\gdal_latest\share") rather than with
--config, as --config is only for GDAL configuration options, and
PROJ_LIB is only read by PROJ which reads environment variable.
And don't set OGR_CT_FORCE_TRADITIONAL_GIS_ORDER=YES. It is not needed here.
Le 08/02/2023 à 11:45, Elena Ruiz a écrit :
> Hello, actually we use several versions of gdal and among them I have
> also tried it with the latest one, 3.6.2 in x64, but it gives me these
> errors:
> /ogr2ogr -f "ESRI Shapefile" "C:\Users\elena\Downloads\Recinto.shp"
> "C:\Users\elena\Downloads\Recinto.gml" --config
> OGR_CT_FORCE_TRADITIONAL_GIS_ORDER YES --config PROJ_LIB
> "D:\MDT\V9\bin\gdal\gdal_latest\share"/
> /ERROR 1: PROJ: proj_create: no database context specified/
> /ERROR 1: Field gml_id has a NULL content which is not allowed/
> /ERROR 1: Unable to write feature 0 from layer LandCoverUnit./
> /ERROR 1: Terminating translation prematurely after failed/
> /translation of layer LandCoverUnit (use -skipfailures to skip errors)/
> But several things happen, it does not establish the PROJ_LIB
> directory, I am indicating the directory where the proj.db is, but it
> ignores it, I don't know if it needs something else. It is not
> recognizing the OGR_CT_FORCE_TRADITIONAL_GIS_ORDER label either,
> because the destination file has not modified the order of the axes,
> and finally it detects some errors in the GML file, and the example
> file is a correct GML
> (https://aplitop.sharefile.com/d-scfcb397f54a649598913d6ae00d0d398 ).
> Thank you and I hope someone can help me, regards
> *Elena Ruiz*
> Sofware Development & Technical Support
> Tel.: +34 952 43 97 71
> eruiz at aplitop.com
> *www.aplitop.com*
> *De:*Even Rouault <even.rouault at spatialys.com>
> *Enviado el:* miércoles, 8 de febrero de 2023 11:10
> *Para:* Elena Ruiz <eruiz at aplitop.com>; gdal-dev at lists.osgeo.org
> *Asunto:* Re: [gdal-dev] Set axis order with ogr2ogr
> Elena,
> I almost choked when reading "I'm using GDAL 1.1.1". Do you realize
> this version was released 16 years ago ? Even GDAL 2.4.4 is
> antiquated. Nobody longer support those versions. Please upgrade to a
> recent (< 2 years) version first. I've just verified that ogr2ogr
> works just fine on our file with a recent version
> Even
> Le 08/02/2023 à 10:40, Elena Ruiz a écrit :
> Hello, I need to do a conversion between GML to SHP vector files
> with the app ogr2ogr.exe, and be able to set the order of the axes
> TRADITIONAL_GIS_ORDER / AUTHORITY_COMPLIANT, in the OGR API
> documentation (ogr_srs_api.h), I found the following:
> /"This will honor the axis order advertised by the source and
> target SRS, as well as their “data axis to SRS axis mapping”. To
> have a behavior similar to GDAL < 3.0, the
> OGR_CT_FORCE_TRADITIONAL_GIS_ORDER configuration option can be set
> to YES."/
> And from here I have deduced that I could use the
> OGR_CT_FORCE_TRADITIONAL_GIS_ORDER tag to establish the order of
> the axes and I have used the following command line:
> "C:\Users\elena\Downloads\Recinto.gml" -co
> OGR_CT_FORCE_TRADITIONAL_GIS_ORDER YES/
> I am using GDAL 1.1.1 on x86, for this version of GDAL it does
> create the SHP file, it does not give an error when executed, but
> it does not make any change in the order of the axes of the
> destination file.
> But I have also tried it with version 2.4.4 for x64 and in this
> case it gives me the following errors:
> errors)/
> I attach an example file in the following link:
> I hope someone can tell me how I can do what I need, thanks and
> regards.
> *Elena Ruiz *
> Tel. +34 952 43 97 71
> Sumatra, 9 - 29190 Málaga (Spain)
> *www.aplitop.com <http://www.aplitop.com>**
> *** <https://www.facebook.com/AplitopSL/>****
> <https://twitter.com/aplitop>****
> <https://www.linkedin.com/company/aplitop>****
> <https://www.youtube.com/user/aplitop>
> In accordance with the provisions of the European Regulation of
> Data Protection 2016/679 (Reglamento Europeo de Protección de
> Datos 2016/679), we inform you that the data and the information
> you provide us through this medium will be used by APLITOP, S.L.,
> with C.I.F. B-92543396 and with address at C / Sumatra, 9, Malaga,
> 29190, in order to answer your questions and inform you about our
> products. The data provided will be kept as long as it does not
> request its cessation and will not be transferred to third parties
> except in cases where there is a legal obligation. You have the
> right to access your personal data, correct inaccurate data or
> request its deletion when the data is no longer necessary for the
> purposes that were collected, as well as any rights recognized in
> the RGPD 2016/679
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230208/4af93440/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230208/4af93440/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230208/4af93440/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230208/4af93440/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230208/4af93440/attachment-0007.png>
