[gdal-dev] PROJ Data
Paul Harwood
runette at gmail.com
Wed Feb 8 13:50:41 PST 2023
If you don't have access to the PROJ data then there are Spatial
References(CRS) and Spatial Transformations that it will not know about.
However - you can set GDAL up to use the PROJ CDN - so that it pulls down
just the data it needs when it needs it.
On Wed, 8 Feb 2023 at 21:44, Scott Arnold <scottcarnold2 at gmail.com> wrote:
> Greetings GDAL Community,
> I've been working with GDAL lately, and I have a question for more
> experienced GDAL users or developers. GDAL has a dependency on PROJ. I
> know some GDAL functions, for example, will respond with an error message
> if the proj.db cannot be found, and there is a dependency on PROJ during
> the GDAL build. PROJ has a rather large collection of data packaged
> separately from the PROJ source code (described in PROJ-data readme as
> containing shift grids for horizontal and vertical coordinate
> transformations.). You can build both PROJ and GDAL without PROJ data, and
> the GDAL functions I've used (albeit I've only used a few) seem unaffected
> by not having PROJ data. Can any of you provide any insights into what the
> implications are of having PROJ data installed vs. not installed?
> Thank you,
> Scott Arnold
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230208/dc8e471c/attachment.htm>
