[gdal-dev] Error when trying to build Docker Images
Laurențiu Nicola lnicola at dend.ro
Tue Feb 14 10:03:01 PST 2023
Is that an arm64 system?
Laurentiu
On Tue, Feb 14, 2023, at 20:00, Dirk Stenger wrote:
> All,
> Unfortunately, when trying to build the GDAL Docker Image on a local machine (Ubuntu 22.04), the build fails with an error:
> Executed commands and logging:
> ~/git/gdal/docker/ubuntu-small$ ./build.sh
> debconf: delaying package configuration, since apt-utils is not installed
> Fetched 70.5 MB in 39s (1795 kB/s)
> Selecting previously unselected package libpython3.10-minimal:arm64.
> (Reading database ... 19054 files and directories currently installed.)
> Preparing to unpack .../libpython3.10-minimal_3.10.6-1~22.04.2_arm64.deb ...
> Unpacking libpython3.10-minimal:arm64 (3.10.6-1~22.04.2) ...
> Selecting previously unselected package libexpat1:arm64.
> Preparing to unpack .../libexpat1_2.4.7-1ubuntu0.2_arm64.deb ...
> Unpacking libexpat1:arm64 (2.4.7-1ubuntu0.2) ...
> Selecting previously unselected package python3.10-minimal:arm64.
> Preparing to unpack .../python3.10-minimal_3.10.6-1~22.04.2_arm64.deb ...
> Unpacking python3.10-minimal:arm64 (3.10.6-1~22.04.2) ...
> Setting up libpython3.10-minimal:arm64 (3.10.6-1~22.04.2) ...
> Setting up libexpat1:arm64 (2.4.7-1ubuntu0.2) ...
> Setting up python3.10-minimal:arm64 (3.10.6-1~22.04.2) ...
> /var/lib/dpkg/info/python3.10-minimal.postinst: 51: /usr/bin/python3.10: Exec format error
> dpkg: error processing package python3.10-minimal:arm64 (--configure):
>  installed python3.10-minimal:arm64 package post-installation script subprocess returned error exit status 126
> Errors were encountered while processing:
> E: Sub-process /usr/bin/dpkg returned an error code (1)
> The command '/bin/sh -c . /buildscripts/bh-set-envvars.sh     && apt-get update -y     && DEBIAN_FRONTEND=noninteractive apt-get install -y --fix-missing --no-install-recommends        python3-dev${APT_ARCH_SUFFIX} python3-numpy${APT_ARCH_SUFFIX} python3-setuptools${APT_ARCH_SUFFIX}        libjpeg-dev${APT_ARCH_SUFFIX} libgeos-dev${APT_ARCH_SUFFIX}        libexpat-dev${APT_ARCH_SUFFIX} libxerces-c-dev${APT_ARCH_SUFFIX}        libwebp-dev${APT_ARCH_SUFFIX} libpng-dev${APT_ARCH_SUFFIX}        libzstd-dev${APT_ARCH_SUFFIX} bash zip curl        libpq-dev${APT_ARCH_SUFFIX} libssl-dev${APT_ARCH_SUFFIX} libopenjp2-7-dev${APT_ARCH_SUFFIX}        libspatialite-dev${APT_ARCH_SUFFIX}        autoconf automake sqlite3 bash-completion' returned a non-zero code: 100
> The same behavior occurs with ubuntu-full:
> ~/git/gdal/docker/ubuntu-full$ ./build.sh
> Fetched 466 MB in 3min 39s (2128 kB/s)
> Selecting previously unselected package libcap2:arm64.
> (Reading database ... 19051 files and directories currently installed.)
> Preparing to unpack .../libcap2_1%3a2.44-1build3_arm64.deb ...
> Unpacking libcap2:arm64 (1:2.44-1build3) ...
> Selecting previously unselected package libgpg-error0:arm64.
> Preparing to unpack .../libgpg-error0_1.43-3_arm64.deb ...
> Unpacking libgpg-error0:arm64 (1.43-3) ...
> Selecting previously unselected package libgcrypt20:arm64.
> Preparing to unpack .../libgcrypt20_1.9.4-3ubuntu3_arm64.deb ...
> Unpacking libgcrypt20:arm64 (1.9.4-3ubuntu3) ...
> Selecting previously unselected package liblz4-1:arm64.
> Preparing to unpack .../liblz4-1_1.9.3-2build2_arm64.deb ...
> Unpacking liblz4-1:arm64 (1.9.3-2build2) ...
> Setting up libcap2:arm64 (1:2.44-1build3) ...
> Setting up libgpg-error0:arm64 (1.43-3) ...
> Setting up libgcrypt20:arm64 (1.9.4-3ubuntu3) ...
> Setting up liblz4-1:arm64 (1.9.3-2build2) ...
> Selecting previously unselected package libsystemd0:arm64.
> (Reading database ... 19059 files and directories currently installed.)
> Preparing to unpack .../libsystemd0_249.11-0ubuntu3.6_arm64.deb ...
> Unpacking libsystemd0:arm64 (249.11-0ubuntu3.6) ...
> The command '/bin/sh -c . /buildscripts/bh-set-envvars.sh     && apt-get update -y     && DEBIAN_FRONTEND=noninteractive apt-get install -y --fix-missing --no-install-recommends        libopenjp2-7-dev${APT_ARCH_SUFFIX} libcairo2-dev${APT_ARCH_SUFFIX}        python3-dev${APT_ARCH_SUFFIX} python3-numpy${APT_ARCH_SUFFIX} python3-setuptools${APT_ARCH_SUFFIX}        libpng-dev${APT_ARCH_SUFFIX} libjpeg-dev${APT_ARCH_SUFFIX} libgif-dev${APT_ARCH_SUFFIX} liblzma-dev${APT_ARCH_SUFFIX} libgeos-dev${APT_ARCH_SUFFIX}        curl libxml2-dev${APT_ARCH_SUFFIX} libexpat-dev${APT_ARCH_SUFFIX} libxerces-c-dev${APT_ARCH_SUFFIX}        libnetcdf-dev${APT_ARCH_SUFFIX} libpoppler-dev${APT_ARCH_SUFFIX} libpoppler-private-dev${APT_ARCH_SUFFIX}        libspatialite-dev${APT_ARCH_SUFFIX} librasterlite2-dev${APT_ARCH_SUFFIX} swig ant libhdf4-alt-dev${APT_ARCH_SUFFIX} libhdf5-serial-dev${APT_ARCH_SUFFIX}        libfreexl-dev${APT_ARCH_SUFFIX} unixodbc-dev${APT_ARCH_SUFFIX}  mdbtools-dev${APT_ARCH_SUFFIX} libwebp-dev${APT_ARCH_SUFFIX}        liblcms2-2 libpcre3-dev${APT_ARCH_SUFFIX} libcrypto++-dev${APT_ARCH_SUFFIX} libfyba-dev${APT_ARCH_SUFFIX}        libkml-dev${APT_ARCH_SUFFIX} libmysqlclient-dev${APT_ARCH_SUFFIX} libogdi-dev${APT_ARCH_SUFFIX}        libcfitsio-dev${APT_ARCH_SUFFIX} openjdk-"$JAVA_VERSION"-jdk${APT_ARCH_SUFFIX} libzstd-dev${APT_ARCH_SUFFIX}        libpq-dev${APT_ARCH_SUFFIX} libssl-dev${APT_ARCH_SUFFIX} libboost-dev${APT_ARCH_SUFFIX}        autoconf automake bash-completion libarmadillo-dev${APT_ARCH_SUFFIX}        libopenexr-dev${APT_ARCH_SUFFIX} libheif-dev${APT_ARCH_SUFFIX}        libdeflate-dev${APT_ARCH_SUFFIX} libblosc-dev${APT_ARCH_SUFFIX} liblz4-dev${APT_ARCH_SUFFIX} libbz2-dev${APT_ARCH_SUFFIX}        libbrotli-dev${APT_ARCH_SUFFIX}        libarchive-dev${APT_ARCH_SUFFIX}     && rm -rf /var/lib/apt/lists/*' returned a non-zero code: 100
> This is the used Docker version:
> docker --version
> Docker version 20.10.17, build 100c701
> I tried to build the *master* branch and *release/3.5* branch.
> Can anyone help why the build is failing?
> Kind regards,
> Dirk Stenger
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230214/5e540e98/attachment.htm>
