[gdal-dev] Segmentation fault while compiling
afernandez
afernandez at odyhpc.com
Wed Feb 15 18:04:40 PST 2023
The problem doesn't seem to be about having 2 copies of PROJ as I checked. I was able to compile v3.6.2 w/o this issue so it might be something in the master branch (maybe the python script that you mention).
Even Rouault wrote:
This is a new Python script that runs the Python bindings and use PROJ functionality. Aren't you running into the issue of having 2 PROJ versions described in https://github.com/OSGeo/gdal/pull/7250 <https://github.com/OSGeo/gdal/pull/7250> ?
If you don't need to run GDAL tests, you can add -DBUILD_TESTING=OFF to your CMake invokation and that will avoid running this script. But the crash indicates something fishy that might hit you at execution of your GDAL build
Le 16/02/2023 à 00:20, afernandez a écrit :
Hello,
I'm trying to compile GDAL from source in order to include the KEA components. My attempt at compiling (configured simply with cmake .. -DCMAKE_INSTALL_PREFIX=/usr) failed towards the end with a segmentation fault error, which I cannot figure out
[ 98%] Built target testlog
[ 98%] Building CXX object autotest/cpp/CMakeFiles/test_osr_set_proj_search_paths.dir/test_osr_set_proj_search_paths.cpp.o
[ 98%] Building CXX object autotest/cpp/CMakeFiles/test_osr_set_proj_search_paths.dir/main_gtest.cpp.o
[ 98%] Linking CXX executable test_osr_set_proj_search_paths
[ 98%] Built target test_osr_set_proj_search_paths
[ 98%] Building CXX object autotest/cpp/CMakeFiles/proj_with_fork.dir/proj_with_fork.cpp.o
[ 98%] Building CXX object autotest/cpp/CMakeFiles/proj_with_fork.dir/main_gtest.cpp.o
[ 98%] Linking CXX executable proj_with_fork
[ 98%] Built target proj_with_fork
[ 98%] Building CXX object autotest/CMakeFiles/pytest_runner.dir/pytest_runner.cpp.o
[ 98%] Linking CXX executable pytest_runner
[ 98%] Built target pytest_runner
Segmentation fault
make[2]: *** [autotest/CMakeFiles/run_setup_proj_db_tmpdir.dir/build.make:70: autotest/CMakeFiles/run_setup_proj_db_tmpdir] Error 1
make[1]: *** [CMakeFiles/Makefile2:12792: autotest/CMakeFiles/run_setup_proj_db_tmpdir.dir/all] Error 2
make: *** [Makefile:146: all] Error 2
Thanks.
P.S. OS is Ubuntu22.04 and architecture is aarch64; GDAL is cloned from Github
_______________________________________________ gdal-dev mailing list gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org> https://lists.osgeo.org/mailman/listinfo/gdal-dev <https://lists.osgeo.org/mailman/listinfo/gdal-dev> -- http://www.spatialys.com <http://www.spatialys.com> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230216/f6b05037/attachment.htm>
