[gdal-dev] help with (docker) build workflow
Michael Sumner mdsumner at gmail.com
Sun Feb 19 10:48:18 PST 2023
Ah, awesome - thanks Even and Daniel, both very helpful.
Cheers, Mike
On Mon, Feb 20, 2023 at 5:36 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> Michael,
> for your use case, you are only interested in the "builder" image, not the
> "runner" one.
> So just build it with something like: docker build . --target builder -t
> whatever_tag_name_you_want
> Even
> Le 19/02/2023 à 19:08, Michael Sumner a écrit :
> I would like to build GDAL in an image on the basis of a dockerfile used
> for CI, I'm confused by the layer process that copies the build outputs for
> the final steps
> https://github.com/OSGeo/gdal/blob/master/docker/ubuntu-small/Dockerfile#L231
> I want to be able to run that image and then do my own builds with cmake -
> but the layer COPY process doesn't include cmake or the other prereqs used
> above (to save space in the image).
> Is it easy to include the build capability as a layer-copy step?
> Or is this perhaps a bad idea, I'm looking for the easiest way to get a
> build system running with docker - I can unpick the builder/COPY process,
> but maybe I'm missing something easy.
> Thank you
> Michael Sumner
> Software and Database Engineer
> Australian Antarctic Division
> Hobart, Australia
> e-mail: mdsumner at gmail.com
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
Michael Sumner
Hobart, Australia
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230220/c9c00bed/attachment.htm>
