[gdal-dev] CSV driver option to set the quote character for input -oo
Even Rouault
even.rouault at spatialys.com
Thu Feb 23 07:29:36 PST 2023
Should be fixed per https://github.com/OSGeo/gdal/pull/7305
Even
Le 22/02/2023 à 19:55, Robert Hewlett a écrit :
> Hi,
> Ran into a problem with a CSV driver where I need more control over
> setting the quote character. It may already be there but I cannot find
> it on the -oo side. It is there on the writer side -co.
> The data is real-world data so it is a mess; unpaired single and
> double quotes within a field.
> When I use the copy for postgresql at the command line and use '\b' as
> the quote character, I can get all the data in. However, the ogr2ogr
> CSV driver really wants to pair up the quotes.
> Is there a no quote option or a way to set '\b' as the quote character?
> Thanks,
> Rob
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
