[gdal-dev] GetAreaOfUse() and EPSG:29902
Even Rouault
even.rouault at spatialys.com
Tue Jan 3 09:51:18 PST 2023
Simon,
epsg.io is not a reference site. You should rather consult epsg.org
For CRS EPSG:29902, it refers to extent
https://epsg.org/extent_3767/Ireland-onshore.html which has -5.93° as
east longitude
https://epsg.org/extent_1305/Europe-Ireland-Republic-and-Ulster-onshore.html
has -5.34° as east longitude. So epsg.io is perhaps confused by which
extent to use, or an update has occured between the last state of the
database it used and today.
Even
Le 03/01/2023 à 18:33, Simon Wright a écrit :
> Dear All
> Happy New Year!
> I’m trying to use the GetAreaOfUse() method on a
> osgeo.osr.SpatialReference to check the validity of coordinates.
> With the following for the Irish National Grid (EPSG:29902) I get the
> WGS84 bounds – west, east, south, north - of the spatial reference
> system to be -10.56, -5.93, 51.39, 55.43:
> >>> from osgeo import osr
> >>> srs = osr.SpatialReference()
> >>> srs.ImportFromEPSG(29902)
> 0
> >>> aou = srs.GetAreaOfUse()
> >>> aou.west_lon_degree, aou.east_lon_degree, aou.south_lat_degree,
> aou.north_lat_degree
> (-10.56, -5.93, 51.39, 55.43)
> However, at https://epsg.io/29902 the WGS84
> <https://epsg.io/29902%20the%20WGS84> bounds are listed as -10.56,
> -5.34, 51.39, 55.43.
> How is the GetAreaOfUse() method implemented? And is there a bug in
> the values stored for the EPSG:29902 projection? Or is there another
> reason why the values differ to those listed at epsg.io.
> Many thanks, best wishes, Simon.
> *Simon Wright*
> *JBA Risk Management Limited*
> e: *Simon.Wright at jbarisk.com* <mailto:Simon.Wright at jbarisk.com>
> d: +44 (0)1756 587258
> t: *+44 (0)1756 799919* <tel:+44%20(0)1756%20799919>
> *www.jbarisk.com* <http://www.jbarisk.com/>
> Facebook <https://www.facebook.com/TheFloodPeople>
> LinkedIn <https://www.linkedin.com/company/jba-risk-management/>
> Twitter <https://twitter.com/JBARisk>
> YouTube <https://www.youtube.com/channel/UC0iatom2jYbW96voW0rlpCw>
> All JBA Risk Management's email messages contain confidential
> information and are intended only for the individual(s) named. If you
> are not the named addressee you should not disseminate, distribute or
> copy this e-mail.
> Please notify the sender immediately by email if you have received
> this email by mistake and delete this email from your system.
> JBA Risk Management Limited is registered in England, company number
> 07732946, 1 Broughton Park, Old Lane North, Broughton, Skipton, North
> Yorkshire, BD23 3FD, England.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230103/5b856e13/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230103/5b856e13/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230103/5b856e13/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230103/5b856e13/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230103/5b856e13/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230103/5b856e13/attachment-0009.png>
