[gdal-dev] gdal git - Test 28 test-virtual-memory (SEGFAULT)
Andrew C Aitchison
andrew at aitchison.me.uk
Thu Jan 12 14:23:43 PST 2023
On Thu, 12 Jan 2023, Even Rouault wrote:
> Andrew,
> how did you get clang 15.0.2 on Ubuntu 21:10 ? Not through the apt package
> manager with the default apt repositories, right ? Because I've just tried
> with ubuntu 22.04 and this is only clang 14.0.0 that gets distributed, and
> the test runs fine.
'sudo apt reinstall clang-15' gives:
Get:1 http://gb.archive.ubuntu.com/ubuntu kinetic/universe amd64 clang-15
amd64 1:15.0.2-1 [80.5 kB]
Fetched 80.5 kB in 0s (205 kB/s)
(Reading database ... 1008451 files and directories currently installed.)
Preparing to unpack .../clang-15_1%3a15.0.2-1_amd64.deb ...
Unpacking clang-15 (1:15.0.2-1) over (1:15.0.2-1) ...
Setting up clang-15 (1:15.0.2-1) ...
I think the "universe" and "clang-15" might be the significant differences.
> That said, I'm moderately surprised that you hit an issue. The virtualmem
> code stuff does some on-the-fly at-hand un-assembling (cf
> https://gdal.org/development/rfc/rfc45_virtualmem.html#low-level-machinery-cpl-virtualmem-h),
> so if a compiler emits new machine instructions the code isn't ready for,
> such errors could happen. So, assuming the compiler you use isn't broken, I
> suspect some code updates are required. But we need to be able to reproduce
> first. Did you also use particular CPPFLAGS that activate AVX instruction set
> or something like that ?
Not explicitly, but
autotest/cpp/CMakeFiles/testvirtualmem.dir/flags.make
does mention such things, though the flags in the clang-14 version
are no different. Here it is in full:
# CMAKE generated file: DO NOT EDIT!
# Generated by "Unix Makefiles" Generator, CMake Version 3.24
# compile CXX with /usr/lib/llvm-15/bin/clang++
CXX_DEFINES = -DDONT_DEPRECATE_SPRINTF -DGDAL_COMPILATION -DGDAL_TEST_ROOT_DIR=\"/home/werdna/git/gdal/autotest\" -DHAVE_AVX_AT_COMPILE_TIME -DHAVE_SSE_AT_COMPILE_TIME -DHAVE_SSSE3_AT_COMPILE_TIME
CXX_INCLUDES = -I/home/werdna/git/gdal/apps -I/home/werdna/git/gdal/alg -I/home/werdna/git/gdal/gcore -I/home/werdna/git/gdal.build.llvm/gcore -I/home/werdna/git/gdal/port -I/home/werdna/git/gdal.build.llvm/port -I/home/werdna/git/gdal/ogr -I/home/werdna/git/gdal/ogr/ogrsf_frmts -I/home/werdna/git/gdal/frmts -I/home/werdna/git/gdal.build.llvm/gcore/gdal_version_full
CXX_FLAGS = -fno-finite-math-only -fvisibility=hidden -g -Wall -Wextra -Winit-self -Wunused-parameter -Wmissing-declarations -Wshorten-64-to-32 -Wshadow -Wshadow-field -Wmissing-include-dirs -Wformat -Werror=format-security -Wno-format-nonliteral -Werror=vla -Wdate-time -Wnull-dereference -Wextra-semi -Wcomma -Wfloat-conversion -Wdocumentation -Wno-documentation-deprecated-sync -Wunused-private-field -Wnon-virtual-dtor -Woverloaded-virtual -Wsuggest-override -fno-operator-names -Wzero-as-null-pointer-constant -DGTEST_HAS_PTHREAD=1 -std=gnu++11
The overall CMakeCache.txt is at
https://www.aitchison.me.uk/gdal/CMakeCache.txt.clang15.20230112.txt
> Apart from the inconvenience of the test suite not passing, that doesn't
> invalidate your GDAL build in general. This is a very specific functionality
> that no one triggers without explicitly asking for it.
> Even
Thanks.
Andrew C. Aitchison Kendal, UK
