[gdal-dev] Motion: Approve RFC90: Direct access to compressed raster data
Sean Gillies sean.gillies at gmail.com
Mon Jan 16 12:17:34 PST 2023
I'm +1. Norman Barker wrote something like this when we worked together, so
I get the point of it clearly.
https://www.rfc-editor.org/rfc/rfc6838#page-13 has some things to say about
the parameters returned by GetCompressionFormat after, e.g., "image/jpeg".
* Parameters are case insensitive
* Order has no meaning
* More than one instance of a parameter is an error
It's possible that some image media types are defined so that no such
parameters are allowed. I don't see that this is the case for image/jpeg,
so we're probably fine.
If we don't want to think about official media types at all, which might be
a good idea, couldn't we use driver names instead? "JPEG; foo=bar" instead
of "image/jpeg; foo=bar" for example.
On Mon, Jan 16, 2023 at 10:03 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi,
> Motion: Approve RFC90: Direct access to compressed raster data:
> https://github.com/OSGeo/gdal/pull/7020
> Starting with my +1
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230116/33224555/attachment.htm>
