[gdal-dev] near identical files being treated differently
Ken Mankoff
mankoff at gmail.com
Mon Jan 23 04:46:15 PST 2023
Hello,
I have two near-identical files available at:
wget https://portal.nccs.nasa.gov/GISS_modelE/modelE_input_data/GLMELT_4X5.OCN.nc
wget https://portal.nccs.nasa.gov/GISS_modelE/modelE_input_data/GLMELT_144X90_gas.OCN.nc
They differ only in their dimensions:
$ diff <(ncdump -h GLMELT_4X5.OCN.nc) <(ncdump -h GLMELT_144X90_gas.OCN.nc)|cat -n
1 1c1
2 < netcdf GLMELT_4X5.OCN {
3 ---
4 > netcdf GLMELT_144X90_gas.OCN {
5 3,4c3,4
6 < lon = 72 ;
7 < lat = 46 ;
8 ---
9 > lon = 144 ;
10 > lat = 90 ;
However, "galinfo" sees them differently, and therefore they are treated very differently in, for example, QGIS.
$ diff <(gdalinfo GLMELT_4X5.OCN.nc) <(gdalinfo GLMELT_144X90_gas.OCN.nc)|cat -n
1 2,3c2,6
2 < Files: GLMELT_4X5.OCN.nc
3 < Size is 72, 46
4 ---
5 > Files: GLMELT_144X90_gas.OCN.nc
6 > GLMELT_144X90_gas.OCN.nc.aux.xml
7 > Size is 144, 90
8 > Origin = (-180.000000000000000,90.000000000000000)
9 > Pixel Size = (2.500000000000000,-2.000000000000000)
10 8,13c11,18
11 < Upper Left ( 0.0, 0.0)
12 < Lower Left ( 0.0, 46.0)
13 < Upper Right ( 72.0, 0.0)
14 < Lower Right ( 72.0, 46.0)
15 < Center ( 36.0, 23.0)
16 < Band 1 Block=72x1 Type=Float32, ColorInterp=Undefined
17 ---
18 > Upper Left (-180.0000000, 90.0000000)
19 > Lower Left (-180.0000000, -90.0000000)
20 > Upper Right ( 180.0000000, 90.0000000)
21 > Lower Right ( 180.0000000, -90.0000000)
22 > Center ( 0.0000000, 0.0000000)
23 > Band 1 Block=144x1 Type=Float32, ColorInterp=Undefined
24 > Min=0.000 Max=1.000
25 > Minimum=0.000, Maximum=1.000, Mean=0.018, StdDev=0.134
26 16a22,25
27 > STATISTICS_MAXIMUM=1
28 > STATISTICS_MEAN=0.018364197530864
29 > STATISTICS_MINIMUM=0
30 > STATISTICS_STDDEV=0.13426449188044
That is, the larger file contains key info:
Which then generates correct Corner Coordinates.
Given that the 'ncdump' of the two files is identical (except size), can someone clarify what I'm doing wrong here?
Thanks,
Ken Mankoff
