[gdal-dev] Build difficulties (Ubuntu 20.04)
Anja Sheppard anjashep at umich.edu
Mon Jan 23 15:05:47 PST 2023
Hello gdal community--
I am new to this tool, and am trying to build it on Ubuntu 20.04. I don't
use conda, so I'm running into problems with the dependencies. I downloaded
the current release .tar.gz file from https://gdal.org/download.html and
then unpacked it. I then followed the instructions on the build help
website which I found through the readme. I ran:
*$ mkdir build*
*$ cd build*
*$ cmake ..*
And then the result was the output pasted at the end of this email.
What are the dependencies that I can just install with apt? I don't use
conda or any of the other package managers listed in the readme. Any help
is appreciated.
Alternatively, if anyone has any other tools that can be used for
converting .DAT to .IMG or .JPG files, I would be very eager to hear more.
I have not been able to successfully view a .DAT image from the NASA PDS
website as of yet.
Thanks,
Anja Sheppard
*-- The C compiler identification is GNU 9.4.0-- The CXX compiler
identification is GNU 9.4.0-- Check for working C compiler: /usr/bin/cc--
Check for working C compiler: /usr/bin/cc -- works-- Detecting C compiler
ABI info-- Detecting C compiler ABI info - done-- Detecting C compile
features-- Detecting C compile features - done-- Check for working CXX
compiler: /usr/bin/c++-- Check for working CXX compiler: /usr/bin/c++ --
works-- Detecting CXX compiler ABI info-- Detecting CXX compiler ABI info -
done-- Detecting CXX compile features-- Detecting CXX compile features -
done-- Performing Test test_sse-- Performing Test test_sse - Success--
Looking for C++ include xmmintrin.h-- Looking for C++ include xmmintrin.h -
found-- Performing Test test_sse2-- Performing Test test_sse2 - Success--
Looking for C++ include emmintrin.h-- Looking for C++ include emmintrin.h -
found-- Performing Test test_ssse3-- Performing Test test_ssse3 - Success--
Looking for C++ include tmmintrin.h-- Looking for C++ include tmmintrin.h -
found-- Performing Test test_sse4.1-- Performing Test test_sse4.1 -
Success-- Looking for C++ include smmintrin.h-- Looking for C++ include
smmintrin.h - found-- Performing Test test_avx-- Performing Test test_avx -
Success-- Looking for C++ include immintrin.h-- Looking for C++ include
immintrin.h - found-- Performing Test test_avx2-- Performing Test test_avx2
- Success-- Found Python: /usr/bin/python3.8 (found suitable version
"3.8.10", minimum required is "3.6") found components: Interpreter
Development NumPy -- Performing Test HAVE_WFLAG_ALL-- Performing Test
HAVE_WFLAG_ALL - Success-- Performing Test HAVE_WFLAG_EXTRA-- Performing
Test HAVE_WFLAG_EXTRA - Success-- Performing Test HAVE_WFLAG_INIT_SELF--
Performing Test HAVE_WFLAG_INIT_SELF - Success-- Performing Test
HAVE_WFLAG_UNUSED_PARAMETER-- Performing Test HAVE_WFLAG_UNUSED_PARAMETER -
Success-- Performing Test HAVE_WFLAG_MISSING_PROTOTYPES-- Performing Test
HAVE_WFLAG_MISSING_PROTOTYPES - Success-- Performing Test
HAVE_WFLAG_MISSING_DECLARATIONS-- Performing Test
HAVE_WFLAG_MISSING_DECLARATIONS - Success-- Performing Test
HAVE_WFLAG_SHORTEN_64_TO_32-- Performing Test HAVE_WFLAG_SHORTEN_64_TO_32 -
Failed-- Performing Test HAVE_WFLAG_LOGICAL_OP-- Performing Test
HAVE_WFLAG_LOGICAL_OP - Success-- Performing Test HAVE_WFLAG_SHADOW--
Performing Test HAVE_WFLAG_SHADOW - Success-- Performing Test
HAVE_WFLAG_SHADOW_FIELD-- Performing Test HAVE_WFLAG_SHADOW_FIELD -
Failed-- Performing Test HAVE_WFLAG_MISSING_INCLUDE_DIRS-- Performing Test
HAVE_WFLAG_MISSING_INCLUDE_DIRS - Success-- Performing Test
HAVE_WFLAG_FORMAT_SECURITY-- Performing Test HAVE_WFLAG_FORMAT_SECURITY -
Success-- Performing Test HAVE_WFLAG_ERROR_VLA-- Performing Test
HAVE_WFLAG_ERROR_VLA - Success-- Performing Test HAVE_WFLAG_NO_CLOBBERED--
Performing Test HAVE_WFLAG_NO_CLOBBERED - Success-- Performing Test
HAVE_WFLAG_DATE_TIME-- Performing Test HAVE_WFLAG_DATE_TIME - Success--
Performing Test HAVE_WFLAG_NULL_DEREFERENCE-- Performing Test
HAVE_WFLAG_NULL_DEREFERENCE - Success-- Performing Test
HAVE_WFLAG_DUPLICATE_COND-- Performing Test HAVE_WFLAG_DUPLICATE_COND -
Failed-- Performing Test HAVE_WFLAG_EXTRA_SEMI-- Performing Test
HAVE_WFLAG_EXTRA_SEMI - Success-- Performing Test HAVE_WFLAG_COMMA--
Performing Test HAVE_WFLAG_COMMA - Failed-- Performing Test
HAVE_WFLAG_FLOAT_CONVERSION-- Performing Test HAVE_WFLAG_FLOAT_CONVERSION -
Success-- Performing Test HAVE_WFLAG_DOCUMENTATION_AND_NO_DEPRECATED--
Performing Test HAVE_WFLAG_DOCUMENTATION_AND_NO_DEPRECATED - Failed--
Performing Test HAVE_WFLAG_UNUSED_PRIVATE_FIELD-- Performing Test
HAVE_WFLAG_UNUSED_PRIVATE_FIELD - Failed-- Performing Test
HAVE_WFLAG_NON_VIRTUAL_DTOR-- Performing Test HAVE_WFLAG_NON_VIRTUAL_DTOR -
Success-- Performing Test HAVE_WFLAG_OVERLOADED_VIRTUAL-- Performing Test
HAVE_WFLAG_OVERLOADED_VIRTUAL - Success-- Performing Test
HAVE_WFLAG_SUGGEST_OVERRIDE-- Performing Test HAVE_WFLAG_SUGGEST_OVERRIDE -
Success-- Performing Test HAVE_FLAG_NO_OPERATOR_NAMES-- Performing Test
HAVE_FLAG_NO_OPERATOR_NAMES - Success-- Performing Test
HAVE_GCC_WARNING_ZERO_AS_NULL_POINTER_CONSTANT-- Performing Test
HAVE_GCC_WARNING_ZERO_AS_NULL_POINTER_CONSTANT - Success-- Performing Test
HAVE_WFLAG_OLD_STYLE_CAST-- Performing Test HAVE_WFLAG_OLD_STYLE_CAST -
Success-- Performing Test HAVE_WFLAG_EFFCXX-- Performing Test
HAVE_WFLAG_EFFCXX - Success-- Looking for vsnprintf-- Looking for vsnprintf
- found-- Looking for getcwd-- Looking for getcwd - found-- Looking for
fcntl.h-- Looking for fcntl.h - found-- Looking for unistd.h-- Looking for
unistd.h - found-- Looking for sys/types.h-- Looking for sys/types.h -
found-- Looking for locale.h-- Looking for locale.h - found-- Looking for
xlocale.h-- Looking for xlocale.h - not found-- Looking for direct.h--
Looking for direct.h - not found-- Looking for dlfcn.h-- Looking for
dlfcn.h - found-- Looking for stdint.h-- Looking for stdint.h - found--
Looking for stddef.h-- Looking for stddef.h - found-- Check size of int--
Check size of int - done-- Check size of unsigned long-- Check size of
unsigned long - done-- Check size of void*-- Check size of void* - done--
Check size of size_t-- Check size of size_t - done-- Check if the system is
big endian-- Searching 16 bit integer-- Check size of unsigned short--
Check size of unsigned short - done-- Using unsigned short-- Check if the
system is big endian - little endian-- Looking for pthread.h-- Looking for
pthread.h - found-- Performing Test CMAKE_HAVE_LIBC_PTHREAD-- Performing
Test CMAKE_HAVE_LIBC_PTHREAD - Failed-- Looking for pthread_create in
pthreads-- Looking for pthread_create in pthreads - not found-- Looking for
pthread_create in pthread-- Looking for pthread_create in pthread - found--
Found Threads: TRUE  -- Performing Test HAVE_PTHREAD_MUTEX_RECURSIVE--
Performing Test HAVE_PTHREAD_MUTEX_RECURSIVE - Success-- Performing Test
HAVE_PTHREAD_MUTEX_ADAPTIVE_NP-- Performing Test
HAVE_PTHREAD_MUTEX_ADAPTIVE_NP - Success-- Performing Test
HAVE_PTHREAD_SPINLOCK-- Performing Test HAVE_PTHREAD_SPINLOCK - Success--
Performing Test HAVE_5ARGS_MREMAP-- Performing Test HAVE_5ARGS_MREMAP -
Success-- Performing Test HAVE_PTHREAD_ATFORK-- Performing Test
HAVE_PTHREAD_ATFORK - Success-- Looking for sys/stat.h-- Looking for
sys/stat.h - found-- Looking for linux/fs.h-- Looking for linux/fs.h -
found-- Looking for readlink-- Looking for readlink - found-- Looking for
posix_spawnp-- Looking for posix_spawnp - found-- Looking for
posix_memalign-- Looking for posix_memalign - found-- Looking for vfork--
Looking for vfork - found-- Looking for mmap-- Looking for mmap - found--
Looking for sigaction-- Looking for sigaction - found-- Looking for
statvfs-- Looking for statvfs - found-- Looking for statvfs64-- Looking for
statvfs64 - found-- Looking for lstat-- Looking for lstat - found-- Looking
for getrlimit-- Looking for getrlimit - found-- Looking for RLIMIT_AS--
Looking for RLIMIT_AS - found-- Looking for ftell64-- Looking for ftell64 -
not found-- Looking for ftello64-- Looking for ftello64 - found-- Looking
for fseek64-- Looking for fseek64 - not found-- Looking for fseeko64--
Looking for fseeko64 - found-- Looking for stat64-- Looking for stat64 -
found-- Performing Test NO_UNIX_STDIO_64-- Performing Test NO_UNIX_STDIO_64
- Failed-- Looking for fopen64-- Looking for fopen64 - found-- Check size
of off_t-- Check size of off_t - done-- Looking for pread64-- Looking for
pread64 - found-- Looking for ftruncate64-- Looking for ftruncate64 -
found-- Performing Test HAVE_USELOCALE-- Performing Test HAVE_USELOCALE -
Success-- Performing Test HAVE_HIDE_INTERNAL_SYMBOLS-- Performing Test
HAVE_HIDE_INTERNAL_SYMBOLS - Success-- Performing Test
HAVE_GCC_ATOMIC_BUILTINS-- Performing Test HAVE_GCC_ATOMIC_BUILTINS -
Success-- Performing Test HAVE_GCC_BSWAP-- Performing Test HAVE_GCC_BSWAP -
Success-- Performing Test HAVE_SC_PHYS_PAGES-- Performing Test
HAVE_SC_PHYS_PAGES - Success-- Performing Test HAVE_SCHED_GETAFFINITY--
Performing Test HAVE_SCHED_GETAFFINITY - Success-- Performing Test
INT128_TEST-- Performing Test INT128_TEST - Success-- checking if sprintf
can be overloaded for GDAL compilation-- Performing Test
DEPRECATE_SPRINTF-- Performing Test DEPRECATE_SPRINTF - Failed-- Looking
for linux/userfaultfd.h-- Looking for linux/userfaultfd.h - found--
GDAL_VERSION          = 3.6.2-- GDAL_ABI_FULL_VERSION = 32.3.6.2--
GDAL_SOVERSION        = 32-- Could NOT find ODBC (missing: ODBC_LIBRARY
ODBC_INCLUDE_DIR ODBCINST) -- Could NOT find ODBCCPP (missing:
ODBCCPP_LIBRARY ODBCCPP_INCLUDE_DIR) -- Could NOT find MSSQL_ODBC (missing:
MSSQL_ODBC_LIBRARY MSSQL_ODBC_INCLUDE_DIR MSSQL_ODBC_VERSION) -- Could NOT
find MySQL (missing: MYSQL_LIBRARY MYSQL_INCLUDE_DIR) -- Could NOT find
CURL (missing: CURL_LIBRARY CURL_INCLUDE_DIR) -- Performing Test
Iconv_IS_BUILT_IN-- Performing Test Iconv_IS_BUILT_IN - Success-- Found
Iconv: /usr/lib/x86_64-linux-gnu/libc.so  -- Performing Test
_ICONV_SECOND_ARGUMENT_IS_NOT_CONST-- Performing Test
_ICONV_SECOND_ARGUMENT_IS_NOT_CONST - Success-- Performing Test
ICONV_HAS_EXTRA_CHARSETS-- Performing Test ICONV_HAS_EXTRA_CHARSETS -
Success-- Could NOT find LibXml2 (missing: LIBXML2_LIBRARY
LIBXML2_INCLUDE_DIR) -- Could NOT find EXPAT (missing: EXPAT_DIR)-- Found
EXPAT: /usr/lib/x86_64-linux-gnu/libexpat.so (found version "2.2.9") --
Failed to find XercesC (missing: XercesC_LIBRARY XercesC_INCLUDE_DIR
XercesC_VERSION) -- Found ZLIB: /usr/lib/x86_64-linux-gnu/libz.so (found
version "1.2.11") -- Could NOT find Deflate (missing: Deflate_LIBRARY
Deflate_INCLUDE_DIR) -- Could NOT find OpenSSL, try to set the path to
OpenSSL root folder in the system variable OPENSSL_ROOT_DIR (missing:
OPENSSL_CRYPTO_LIBRARY OPENSSL_INCLUDE_DIR SSL Crypto) -- Could NOT find
CryptoPP (missing: CRYPTOPP_LIBRARY CRYPTOPP_TEST_KNOWNBUG
CRYPTOPP_INCLUDE_DIR) CMake Error at
/usr/share/cmake-3.16/Modules/FindPackageHandleStandardArgs.cmake:146
(message):  Could NOT find PROJ (missing: PROJ_LIBRARY PROJ_INCLUDE_DIR)
(Required is  at least version "6.0")Call Stack (most recent call first):
/usr/share/cmake-3.16/Modules/FindPackageHandleStandardArgs.cmake:393
(_FPHSA_FAILURE_MESSAGE)  cmake/modules/packages/FindPROJ.cmake:57
(find_package_handle_standard_args)
cmake/helpers/CheckDependentLibraries.cmake:355 (find_package)
gdal.cmake:264 (include)  CMakeLists.txt:224 (include)-- Configuring
incomplete, errors occurred!*
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230123/44b41aa0/attachment.htm>
