[gdal-dev] Build difficulties (Ubuntu 20.04)
Sebastiaan Couwenberg
sebastic at xs4all.nl
Mon Jan 23 22:14:27 PST 2023
On 1/24/23 06:28, dg0yt at darc.de wrote:
> I would suggest to look at the gdal packaging in Ubuntu or Debian. There are "make-depends" in the dsc files or in debian/control.
> My entry page is
> https://tracker.debian.org/pkg/gdal
> dsc file are linked via an icon in the "versioned links" on the left side.
> debian/control can be reached via "browse source code" on the right side.
If you want to install the build dependencies, ensure you have deb-src
lines enabled in sources.list and use:
apt build-dep gdal
Kind Regards,
Bas
GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146 50D1 6750 F10A E88D 4AF1
