[gdal-dev] GDAL Overestimating Physical Memory
Even Rouault even.rouault at spatialys.com
Tue Jan 24 16:50:28 PST 2023
Angus,
there has been a recent extra fix that landed in GDAL 3.6.2 that might
possibly help: https://github.com/OSGeo/gdal/pull/6926
Even
Le 25/01/2023 à 01:36, Angus Dickey a écrit :
> Hi all,
> I am running into an issue where GDAL is overestimating the amount of
> physical memory it has leading to it locking up the OS by taking 100%
> of the memory. Here is an example program that illustrates the issue:
> #include <stdio.h>
> #include "gdal.h"
> int main(void) {
>    printf("GDAL version is %s\n", GDALVersionInfo("RELEASE_NAME"));
>    printf("GDAL thinks is has %lld bytes of physical memory\n",
> CPLGetPhysicalRAM());
>    printf("GDAL thinks it has %lld bytes of usable physical memory\n",
> CPLGetUsablePhysicalRAM());
>    return 0;
> When this is compiled with GDAL 3.5.1 on Ubuntu 22.04 we get:
> $ ./get_gdal_memory
> GDAL version is 3.5.1
> GDAL thinks is has 811526475776 bytes of physical memory
> GDAL thinks it has 811526475776 bytes of usable physical memory
> Which is not consistent with the actual available memory:
> $ free -h
>                total        used        free      shared  buff/cache
> available
> Mem:           2.0Gi       148Mi       1.2Gi       0.0Ki 639Mi       1.8Gi
> Swap:          256Mi          0B       256Mi
> So GDAL thinks it has 755GB of memory but it only has 2GB, this causes
> issues with the raster read cache and maybe elsewhere. I suspect this
> is happening because it is running in a Linux container
> <https://linuxcontainers.org/> and GDAL is getting the total physical
> memory of the host, not the container. The strange thing is Linux
> containers use cgroups for memory restrictions and the API docs
> mention it was fixed in GDAL 2.4.0
> <https://gdal.org/api/cpl.html#_CPPv417CPLGetPhysicalRAMv> but I am
> still seeing the issue in 3.5.1.
> Any help or insight would be appreciated; I am happy to provide any
> additional information or testing.
> Thanks,
> Angus
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230125/4fff862f/attachment.htm>
