[gdal-dev] GDAL Overestimating Physical Memory
Even Rouault
even.rouault at spatialys.com
Wed Jan 25 03:49:23 PST 2023
Angus,
I'm not familiar with LXC. I tried to setup LXD with
https://linuxcontainers.org/lxd/introduction/ but it fails with a
mysterious "Error: Failed to create local member network "lxdbr0" in
project "default": Failed generating auto config: Failed to
automatically find an unused IPv4 subnet, manual configuration required"
Anyway, I've attempted in https://github.com/OSGeo/gdal/pull/7124 to
better take into account cgroup to get memory limitation. Could you give
this a try?
Even
Le 25/01/2023 à 06:24, Angus Dickey a écrit :
> Even,
> Thanks for the reply, I went ahead and compiled the latest GDAL 3.6.2
> on Ubuntu 22.04. Unfortunately I ended up with a similar result, GDAL
> thinks it has 755GB of RAM to work with when it only has 2GB:
> $ gdalinfo --version
> GDAL 3.6.2, released 2023/01/02 (debug build)
> $ ./get_gdal_memory
> GDAL version is 3.6.2
> GDAL thinks is has 811526475776 bytes of physical memory
> GDAL thinks it has 811526475776 bytes of usable physical memory
> $ free -h
> total used free shared buff/cache
> available
> Mem: 2.0Gi 148Mi 1.2Gi 0.0Ki 639Mi 1.8Gi
> Swap: 256Mi 0B 256Mi
> My knowledge on the subject is limited but I think Linux containers
> (LXC) uses cgroups and not setrlimit to limit resources, so maybe that
> is why the new changes had no effect. To reproduce this issue you can
> create a container using LXC, LXD, or a hypervision like proxmox
> (what I am using) and call CPLGetUsablePhysicalRAM().
> If there is any other info that might be helpful let me know. I might
> try a Docker container (it also uses cgroups) and is more popular than
> LXC, although it fulfills a different function.
> thanks,
> Angus
> On Tue, Jan 24, 2023 at 5:50 PM Even Rouault
> <even.rouault at spatialys.com> wrote:
> Angus,
> there has been a recent extra fix that landed in GDAL 3.6.2 that
> might possibly help: https://github.com/OSGeo/gdal/pull/6926
> Even
> Le 25/01/2023 à 01:36, Angus Dickey a écrit :
>> Hi all,
>> I am running into an issue where GDAL is overestimating the
>> amount of physical memory it has leading to it locking up the OS
>> by taking 100% of the memory. Here is an example program that
>> illustrates the issue:
>> #include <stdio.h>
>> #include "gdal.h"
>> int main(void) {
>> printf("GDAL version is %s\n", GDALVersionInfo("RELEASE_NAME"));
>> printf("GDAL thinks is has %lld bytes of physical memory\n",
>> CPLGetPhysicalRAM());
>> printf("GDAL thinks it has %lld bytes of usable physical
>> memory\n", CPLGetUsablePhysicalRAM());
>> return 0;
>> When this is compiled with GDAL 3.5.1 on Ubuntu 22.04 we get:
>> $ ./get_gdal_memory
>> GDAL version is 3.5.1
>> Which is not consistent with the actual available memory:
>> $ free -h
>> buff/cache available
>> 639Mi 1.8Gi
>> So GDAL thinks it has 755GB of memory but it only has 2GB, this
>> causes issues with the raster read cache and maybe elsewhere. I
>> suspect this is happening because it is running in a Linux
>> container <https://linuxcontainers.org/> and GDAL is getting the
>> total physical memory of the host, not the container. The strange
>> thing is Linux containers use cgroups for memory restrictions and
>> the API docs mention it was fixed in GDAL 2.4.0
>> <https://gdal.org/api/cpl.html#_CPPv417CPLGetPhysicalRAMv> but I
>> am still seeing the issue in 3.5.1.
>> Any help or insight would be appreciated; I am happy to provide
>> any additional information or testing.
>> Thanks,
>> Angus
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230125/76ea3ff5/attachment-0001.htm>
