[gdal-dev] GDAL Overestimating Physical Memory
Laurențiu Nicola lnicola at dend.ro
Thu Jan 26 07:31:59 PST 2023
On Thu, Jan 26, 2023, at 16:52, Even Rouault wrote:
> Laurențiu,
> are you 100% positive you've tested the updated version of the pull request? I've just given a try to running gdallimits under Docker from a Ubuntu 22.04 host and it successfully takes into account the /sys/fs/cgroup/memory.max limit
I'm afraid not, or at least it's working now. Sorry for the false alarm.
Laurentiu
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230126/7543e212/attachment-0001.htm>
