[gdal-dev] Bad GDB performance
Simon Gröchenig
groechenig at zt-gis.at
Fri Jan 27 06:32:34 PST 2023
ok, thanks.
> Do you know how that CRS was attributed to the layers ? (through some choice in a list of predefined CRS ? no idea how Arc stuff works)
No, a third party tool created the layer. If necessary I can contact the developer.
> I believe this CRS should be identified as EPSG:31255
Yes, that is the correct code.
> Which version of ArcMap / ArcGIS was used to produce this GDB ?
ArcGIS Desktop 10.8.1
Simon
Von: Even Rouault <even.rouault at spatialys.com>
Gesendet: Freitag, 27. Jänner 2023 15:23
An: Simon Gröchenig <groechenig at zt-gis.at>
Cc: gdal-dev at lists.osgeo.org
Betreff: Re: AW: [gdal-dev] Bad GDB performance
Hi Simon,
the GDB is fine. GDAL struggles because it tries to identify the CRS definition from the GDB ( 'PROJCS["GK_31",GEOGCS["GCS_MGI",DATUM["D_MGI",SPHEROID["Bessel_1841",6377397.155,299.1528128]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Gauss_Kruger"],PARAMETER["False_Easting",0.0],PARAMETER["False_Northing",-5000000.0],PARAMETER["Central_Meridian",13.3333333333333],PARAMETER["Scale_Factor",1.0],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]' ) with a known one (EPSG, ESRI) in PROJ CRS database. But there is no match for the GK_31 name so it has to go to slower methods.
I believe this CRS should be identified as EPSG:31255, which in the current ESRI CRS database, is called MGI_Austria_GK_Central:
PROJCS["MGI_Austria_GK_Central",GEOGCS["GCS_MGI",DATUM["D_MGI",SPHEROID["Bessel_1841",6377397.155,299.1528128]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",0.0],PARAMETER["False_Northing",-5000000.0],PARAMETER["Central_Meridian",13.3333333333333],PARAMETER["Scale_Factor",1.0],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]
Even
Le 27/01/2023 à 14:34, Simon Gröchenig a écrit :
Hi Even,
great, thank you!
Is the GDB itself fine? Or is there something I can do to fix the database?
Simon
Von: Even Rouault <even.rouault at spatialys.com><mailto:even.rouault at spatialys.com>
Gesendet: Freitag, 27. Jänner 2023 13:38
An: Simon Gröchenig <groechenig at zt-gis.at><mailto:groechenig at zt-gis.at>; gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Betreff: Re: [gdal-dev] Bad GDB performance
Hi Simon,
fix queued in https://github.com/OSGeo/gdal/pull/7131
Even
Le 27/01/2023 à 06:49, Simon Gröchenig a écrit :
Hi all,
I am struggling with a bad performance at reading FileGeodatabases in QGIS. I hope, this is the place where I can find someone to help me find the bottleneck.
I have uploaded a sample dataset here: https://mega.nz/file/nnxVULyC#QcuGJEHedayIC7b1i14J0X8OBExVfhcb55DnnVtGzuc
Loading a QGIS project containing this GDB (layer Kataster/GST) results in a layer loading time of 5+ seconds according to the QGIS Debugging/Development Tools. I expect less than 1 second to load this dataset.
I appreciate any help to find if it is a GDAL or a dataset issue?
Simon
Vermessungskanzlei Neumayr
Simon Gröchenig - Geoinformation
[cid:image001.jpg at 01D93264.4D30EA30]
Albin Egger-Str. 10
9900 Lienz
Tel: +43 4852-68568-31
Email: groechenig at zt-gis.at<mailto:groechenig at zt-gis.at>
Web: http://www.zt-gis.at/
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230127/938104dc/attachment-0001.htm>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230127/938104dc/attachment-0001.jpg>
