[gdal-dev] Metadata keys in upper or lower case ?
Even Rouault even.rouault at spatialys.com
Mon Jan 30 08:33:56 PST 2023
Louis-Philippe,
there's no recommendation. Each format or community within a format may
have different practices.
Some formats may accept some odd characters (but definitely not '=', as
key/value pairs are stored as "key=value" strings internally), but
keeping to alphanumeric + underscore is the best way to be universally
accepted.
That said you'd better not use several metadata keys that only defer by
case, otherwise you're going to confuse a lot of places in GDAL as
comparisons are done in a case insensitive way. I mean: "foo" and "BAR"
are fine within the same metadata. But not "foo", "Foo" and "FOO".
Even
Le 30/01/2023 à 16:54, Rousseau Lambert,Louis-Philippe (ECCC) a écrit :
> Hi everyone !
> I would like to know if there is a rule or a best practice for a
> raster file's metadata key to be written in upper or lower case ?
>  I read https://gdal.org/user/raster_data_model.html#metadata and saw
> that "/The names are required to be well behaved tokens (no spaces, or
> odd characters//)./" but I didn't read anything about upper vs lower
> cases. While I see examples of both (upper and lower case) in
> different valid files, I would like to know if a documented
> recommendation exists ?
> Thanks
> LP
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230130/539dc1ea/attachment.htm>
