[gdal-dev] Problem opening new format ECMWF grib files
    Even Rouault
    even.rouault at spatialys.com
    Wed Jul 12 06:02:30 PDT 2023
Simon,
please find an issue about that to
https://github.com/OSGeo/gdal/issues/new and attach a dataset
reproducing the issue or a convenient link to such a dataset
Even
Le 11/07/2023 à 21:01, Simon Proud - STFC UKRI via gdal-dev a écrit :
> Hello,
> I'm trying to open a grib format file from ECMWF. The file is
> generated using the ECMWF open data python library as follows:
> from ecmwf.opendata import Client
> client = Client()
> result = client.retrieve(
>     type="fc",
>     param="skt",
>     step="0",
>     target="data.grb2",
> This produces a grib file I can read with cfgrib and eccodes but not
> with gdal:
> >>>gdalinfo data.grib2
>       getdrstemplate: DRS Template 5.42 not defined.
>       ERROR 4: data.grib2 is a grib file, but no raster dataset was
> successfully identified.
>              gdalinfo failed - unable to open 'data.grib2'.
> I suspect this may be due to changes in their grib format, see:
> https://confluence.ecmwf.int/display/COPSRV/Implementation+of+IFS+cycle+48r1+for+CAMS#ImplementationofIFScycle48r1forCAMS-DefaultpackingtypesfordatafromDisseminationandMARS
> Am I correct in this assumption and, if so, is there a way around it
> in GDAL? Otherwise, any clues what could be the problem with this grib?
> Thanks,
> Simon
> *Dr Simon Proud (he/him)*
> *Senior Remote Sensing Scientist*
> RAL Space | National Centre for Earth Observation
> Science and Technology Facilities Council
> simon.proud at stfc.ac.uk<mailto:simon.proud at stfc.ac.uk> |
> www.ralspace.stfc.ac.uk<https://www.ralspace.stfc.ac.uk/>
> Rutherford Appleton Laboratory | Harwell Campus | Didcot
> Tel: +44 1235 445620
> Twitter: @simon_sat
> signature_165909100
> STFC and NCEO are part of UK Research and Innovation.
> www.ukri.org<https://www.ukri.org/>
> Due to childcare arrangements, my normal working hours may not be the
> same as yours. If you receive an email from me at an odd time, please
> do not feel the need to reply until your own normal working day.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230712/fb5b7122/attachment-0001.htm>
