[gdal-dev] How to decrease file size of colored raster bands?
Laurențiu Nicola
lnicola at dend.ro
Thu Jun 1 09:28:56 PDT 2023
There are a couple of things you can try:
• you seem to be scaling the data to 8-bit, but saving it as UInt16; GDT_Byte should work, yielding a 50% reduction. I didn't quite understand the comment about the color, does the palette not work with 8-bit images?
• you can enable and tune compression: check out COMPRESS, PREDICTOR and the level options in https://gdal.org/drivers/raster/gtiff.html. ZSTD and DEFLATE are pretty good.
• you can enable the tiled mode (TILED on the same page as above), which sometimes yields smaller files
• if you find large files difficult to use, you can enable overview creation or use the COG driver (it's a subset of GTiff)
• finally, you can use a lossy compression format like JPEG or LERC, but it's probably not what you want
Regards,
Laurentiu
On Thu, Jun 1, 2023, at 17:35, afernandez wrote:
> Hello,
> I'm generating a raster file with GDAL. The pseudo-code (where the raster is loaded as 'var') for the colored version reads:
> # Initial manipulations
> dims = var.dimensions
> shape = var.shape
> driver_name = 'GTIFF'
> driver = gdal.GetDriverByName(driver_name)
> np_dtype = var.dtype
> type_code = gdal_array.NumericTypeCodeToGDALTypeCode(np_dtype)
> gdal_ds = driver.Create(_my_path_, cols, rows, 1, gdal.GDT_UInt16)
> gdal_ds.SetProjection(_my_projection_)
> gdal_ds.SetGeoTransform(_my_transformation_)
> # Creation of the bands and scaled matrix
> band = gdal_ds.GetRasterBand(1)
> data = var[_chosen_index_]
> data = ma.getdata(data)
> data_scaled = np.interp(data, (data.min(), data.max()), (0, 255))
> data_scaled2 = data_scaled.astype(int) # This is to rescale into integers so that it can color the layer
> # *** Lines to set up the color palette ***
> # Write the array to band once everything has been rescaled
> band.WriteArray(data_scaled2)
> gdal_ds.FlushCache()
> This works well but the problem is that the generated file becomes too large and difficult to work with. If I change to a black and white representation by simply changing the 7th line to:
> gdal_ds = driver.Create(out_path, cols, rows, 1, type_code)
> The new file has a size smaller than 1% of the colored one. I was wondering if there is anything intermediate (with colors but generating a smaller size) or if I would need a more radical approach such as using a driver different from GTIFF or something else.
> Thanks.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230601/e50a9057/attachment-0001.htm>
