[gdal-dev] Java API: how to find dimensions of MDArray
Even Rouault
even.rouault at spatialys.com
Sat Jun 3 09:26:07 PDT 2023
Le 03/06/2023 à 18:16, Barry DeZonia a écrit :
> Ok, thanks. I will consider this for some of my future
> weekend-playtime-programming days. Yes, I'm a masochist.
great, we'd definitely welcome a few ones :-)
> Are there other typemaps needed that would further strengthen the Java
> api support?
Basically most #if defined(SWIGPYTHON) in
https://github.com/OSGeo/gdal/blob/master/swig/include/MultiDimensional.i
<https://github.com/OSGeo/gdal/blob/master/swig/include/MultiDimensional.i#L159>
around a method are an indication that a typemap is missing.
Like:
https://github.com/OSGeo/gdal/blob/92f9cee9a9ed3f114d3e6a63d095ceb09ce85eec/swig/include/MultiDimensional.i#L210
for CreateMDArray() (resolution of that one should be close to the
existing "(int object_list_count, GDALRasterBandShadow **poObjects)"
Java typemap)
https://github.com/OSGeo/gdal/blob/92f9cee9a9ed3f114d3e6a63d095ceb09ce85eec/swig/include/MultiDimensional.i#L464
for GetCoordinateVariables() (resolution of that one should be very
close to the GetDimensions() one)
https://github.com/OSGeo/gdal/blob/master/swig/include/MultiDimensional.i#L477
for GetProcessingChunkSize() (resolution should be close to the existing
"(int* pnCountOut, int** outErrorCodes)" java typemap
- etc..
> On Sat, Jun 3, 2023 at 11:03 AM Even Rouault
> <even.rouault at spatialys.com> wrote:
> Le 03/06/2023 à 17:45, Barry DeZonia a écrit :
>> Thanks Even.
>> I might be able to find some time to do the SWIG work depending
>> upon the amount of development time needed. I am a long time
>> developer with experience in Java, C, and C++ (but have not used
>> SWIG before). Is it just a few signatures I need to write or do I
>> need to write full support for a GDALDimension class? Can you
>> comment on this?
> Yes this is "just" a few signatures to map a C array of (existing)
> GDALDimensionH objects to a vector of Java counterpart
> org.gdal.gdal.Dimension objects. The org.gdal.gdal.Dimension class
> already exists, with a "Dimension(long cPtr, boolean cMemoryOwn)"
> constructor taking the value of the underlying C pointer as a Java
> long. The cMemoryOwn boolean should probably be passed to true in
> that context, since the C GDALDimensionH objects need to be freed
> at the finalization of the Java Dimension object. This is really
> about glueing stuff, but that said writing SWIG typemaps is a
> whole adventure in itself... You may find relevant documentation
> at
> https://www.swig.org/Doc4.1/SWIGDocumentation.html#Java_typemaps
> . The hint I gave for the existing closest typemap should
> hopefully put you on the right track, or at least as close as
> possible.
>> Am I right in understanding that, as of the current Java
>> implementation, one really can't use MDArrays for much? Like if I
>> can't find the number of (... z planes, t steps, channels, etc.)
>> of data I will not be able to reconstruct the data?
> Yes the multidim API is probably currently hardly usable outside
> C, C++ and Python due to the lack of a few critical typemaps for
> the other languages.
> Even
>> On Sat, Jun 3, 2023 at 6:09 AM Even Rouault
>> Barry,
>> This method is indeed not available currently in the Java
>> bindings. It is only available currently in the Python
>> bindings (see
>> ) , since it requires writing a specific SWIG typemap for
>> each binding language when a method returns (or takes as
>> argument) a new non-primitive type such as here, with an
>> array of dimensions. The closest existing Java typemap I
>> found that can be used to take inspiration from is
>> https://github.com/OSGeo/gdal/blob/master/swig/include/java/typemaps_java.i#L235
>> but there would be changes to call the "Dimension(long cPtr,
>> boolean cMemoryOwn)" constructor. Whether you want to try to
>> tackle that yourself or not, you may create a ticket about that
>> Even
>> Le 03/06/2023 à 09:09, Barry DeZonia a écrit :
>>> On a related note is the Java api code in a public repo
>>> somewhere? It would be helpful to look at that code
>>> sometimes. (Like is GetDimensions() present in the Java code
>>> but not exposed as a public method?)
>>> On Sat, Jun 3, 2023 at 12:18 AM Barry DeZonia
>>> <bdezonia at gmail.com> wrote:
>>> Hi all,
>>> I have access to an MDArray. I am trying to find its
>>> dimensions. In the C++ API I can see that GDALMDArray
>>> has a method called GetDimensions() to find the info I
>>> need. But I am programming in Java and the Java API does
>>> not show such a call for MDArray. Is there some way in
>>> Java to find the info I need?
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
>> http://www.spatialys.com
>> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230603/1ba61b5f/attachment-0001.htm>
