[gdal-dev] Minimum python version?
Daniel Baston
dbaston at gmail.com
Tue Jun 13 10:45:19 PDT 2023
The minimum version (3.6) is documented at
https://gdal.org/development/dev_environment.html#build-requirements
The CI still has configurations using Ubuntu 18.04, which is using 3.6.9:
docker run --rm ghcr.io/osgeo/gdal-deps:ubuntu_18.04-master python3
--version
Dan
On Tue, Jun 13, 2023 at 1:22 PM Kurt Schwehr <schwehr at gmail.com> wrote:
> Hi all,
> What is the minimum python version for the GDAL python bindings? This is
> the only thing I found easily:
> find . -type f | grep -v git | xargs grep 3 | grep python_version
> cat autotest/requirements.txt
> pytest>=6.0.0
> pytest-sugar<=0.9.6; python_version < '3.7'
> pytest-sugar; python_version >= '3.7'
> pytest-env
> lxml
> jsonschema
> filelock
> I think the real answer is that it's 3.8 from what I see here:
> swig/python/osgeo/__init__.py
> # The following is a Sequence of tuples in the form of (gdal_version,
> python_version).
> # Each line represents the minimum supported Python version of a given
> GDAL version.
> # Introducing a new line for the next GDAL version will trigger a
> deprecation warning
> # when importing osgeo from a Python version which will not be
> # supported in the next version of GDAL.
> gdal_version_and_min_supported_python_version = (
> ((0, 0), (0, 0)),
> ((1, 0), (2, 0)),
> ((2, 0), (2, 7)),
> ((3, 3), (3, 6)),
> # ((3, 4), (3, 7)),
> # ((3, 5), (3, 8)),
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230613/68077edd/attachment.htm>
